My winter project!
May 10, 2014 | 05:59 PM
FTE Remembers
Not to bad. I'll add a 5-7 deg wedge and take a look...
May 10, 2014 | 06:00 PM
Is the front axle ball joint, or king pin?
May 10, 2014 | 06:02 PM
FTE Remembers
I also cut the old cab mounts off, won't need them. Since I still have the panel frame I have the two forward "cab" mounts and running board brackets to use. Gonna try and get them welded on the frame this week and get the body mounted. Harley and I are sooooo stoked!
May 10, 2014 | 06:03 PM
FTE Remembers
It's a 73 high pinion, open, Dana.....
As you should be!!!
I wish I had an "extra frame " like that here, lol
May 10, 2014 | 06:05 PM
Quote:
Originally Posted by
fabmandelux
So you can put a camber kit in if you need too when you roll it for the drive shaft. Good.
Looks like you have all the loose ends buttoned up!
May 10, 2014 | 06:06 PM
FTE Remembers
The frames not stock any more........ The last time I had it up, I installed a Chevelle front frame section, and a 454..........gasp...........lol
May 10, 2014 | 06:07 PM
FTE Remembers
Front drive shaft is unchanged. I cut the frame behind the T case...
May 10, 2014 | 06:10 PM
fabmandelux
Shhhhhh. I have a 48 f 1 here with a fire bird front clip and a 3 duece 400...... shhhhhhhhh
fabmandelux
ok, that'll work! no problem with camber at all there then, lol
May 10, 2014 | 06:12 PM
FTE Remembers
I'm not a true purest, I visit the dark side................And it can be a blast!
May 10, 2014 | 06:15 PM
My car, my choice. If they don't like it, go look at someone elses.
I have a hard time cutting up a pure car tho, that's why my panel will probably stay mostly stock, except safety issues, like brakes and steering
May 10, 2014 | 06:17 PM
FTE Remembers
Same here.......... I've got stock, almost stock, modded stock, and what the hell was he thinking!....................lol
May 10, 2014 | 06:20 PM
Yeah, and you forgot "someone started this, now I feel sorry for it , and have to fix it "
Or, IDK honey, it followed me home........
May 10, 2014 | 06:23 PM
FTE Remembers
It doesn't follow me home. Most times it get's delivered, FREE!........................lol
May 10, 2014 | 06:24 PM
Same here, Momma has a rollback....LOL
