Parking brake indicator switch
Old Dec 18, 2009 | 10:07 PM
M. P. Gray's Avatar
M. P. Gray
Can anyone tell me where to find the switch that mounts on the parking brake pedal that turns on the red "brake" warning light in the dash instrument panel? Can an aftermarket generic switch be used? Any tips on how to install? Thanks!
Old Dec 18, 2009 | 11:29 PM
mark a.'s Avatar
mark a.
No, because the is no such switch. That light is for the prop. valve in the hydo brake system.
Old Dec 18, 2009 | 11:34 PM
M. P. Gray's Avatar
M. P. Gray
Mark,
Could you explain more thoroughly. What is the "prop valve?" Is the hydro brake system the big round thing that the master cylinder is attached to? Feel free to LOL at my ignorance...Thanks
Old Dec 19, 2009 | 01:05 AM
mikeo0o0o0's Avatar
mikeo0o0o0
The "hydro system" is the hydraulic brake system.
The "prop valve" is the proportioning valve. This valve balances the pressure between the front (disc) brakes and the rear (drum) brakes to keep the rears from locking up, disc brakes require more pressure to operate than drums.
It also has a switch built into it to activate the brake failure light on the dash if either the front or rear systems lose pressure. This is the light you're talking about.
That "big round thing" is your vacuum brake booster, you have power brakes.
Old Dec 19, 2009 | 06:13 AM
Poison Oil Racing's Avatar
Poison Oil Racing
click here, then scroll to the bottom of the page:
LMC Truck Parts - Page 125
Old Dec 19, 2009 | 11:53 AM
steponit's Avatar
steponit
When you first turn the Ign key to on and then start both the BRAKE FAILURE LIGHT and seat belt light illuminate for a few seconds then go out.
It is a bad thing to have the BRAKES Light stay on.
Old Dec 19, 2009 | 12:57 PM
M. P. Gray's Avatar
M. P. Gray
So what's the relationship between the dash light and the parking break? I've always thought that the dash light just informed me that my parking break was still on. How does the parking break trigger the switch? Thanks!
Old Dec 19, 2009 | 03:52 PM
79FordBlake's Avatar
79FordBlake
The parking brake is not associated with the switch.
Old Dec 19, 2009 | 04:00 PM
M. P. Gray's Avatar
M. P. Gray
So, what you're saying is that I'm all wet. The dash light is not a parking break indicator, rather it is a brake system failure warning light and has nothing whatsoever to do with the parking break. Correct? Thus, the parking break is completely manual with no electrical connections at all. Hmmmmmm...
Old Dec 19, 2009 | 04:08 PM
79FordBlake
Nope not a parking light indicator. If the brake light is on the proportioning valve is not centered. Check to see if both the front and back brakes are working. Something may be grounded out making the light come on if you find that your brake system is working properly.
Old Dec 19, 2009 | 04:24 PM
Poison Oil Racing
only newer cars have the indicator light for parking brakes. Our old faithful vehicles weren't that sophisticated
bkmartel
2004 - 2008 F150
May 5, 2017 01:58 PM
Harry Kage
Apr 15, 2017 11:33 AM
steeleygreg
18
Feb 23, 2017 09:01 AM
naiku
1997 - 2003 F150
Nov 1, 2015 01:23 PM
pintoches
Feb 10, 2012 08:38 PM
