push button 4x4 not working on 93 F150
Old 12-18-2009, 06:04 PM
thebiggreenbeast's Avatar
thebiggreenbeast
thebiggreenbeast is offline
need the 4x4 cause of the snow and naturally as my luck sucks it doesnt do anything. any advice of what it mite be?
Old 12-18-2009, 08:14 PM
Hitokori's Avatar
Hitokori
Hitokori is offline
the motor may be burnt up... or rusted to hell and back look at is and then let me know something
Old 12-18-2009, 08:24 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
I can't speak first hand about the F150s but if they're anything like the my '94 Explorer, its likely the motor. If you listen close, can you hear it "trying" to engage under the floor? If so, and if you've tried it 10 or more times, then its time to get under there and give the shift motor a few licks with a BFH. That usually fixes it.
If you don't even hear it trying to engage, then something else is going on.
For the past several years, I've made it a point to engage my 4x4 (high and low) every few weeks, year round. Exercising the motor and such regularly seems to help as I haven't had to try more than twice to engage it since I started doing this.
Good luck!
Old 12-18-2009, 09:03 PM
thebiggreenbeast
yea i get no lights on the push button nor do i get the relay clicking noise... could it be a big fuse under the hood?
Old 12-18-2009, 11:52 PM
TC-Countryboy's Avatar
TC-Countryboy
TC-Countryboy is offline
If you don't hear the relays and the lights don't flash, then I would do as you said, and start looking at fuses. And yes of course you find out isn't working only when you need it. The shift motor on a 94 Bronco I had would hang up once in a while and I would have to use the hammer trick, that is why my current truck has a manual transfer case. It is rare for the stick to hang up.
TC
Old 12-19-2009, 10:37 AM
thebiggreenbeast
i checked the interior fuses and they were good but could not find any associated with the 4x4 system under the hood.....any suggestions?
and you are correct ....no lights or relay clicking on the inside
Old 12-20-2009, 11:18 AM
TC-Countryboy
According to the owners manual for my 95, the electronic shift motor is on a 20 amp circuit breaker at location 12 in the interior fuse panel. Hope this helps.
TC
Old 12-21-2009, 07:37 PM
Dixiesweep's Avatar
Dixiesweep
Dixiesweep is offline
i can hear the relay clicking when i push the 4x4 button. But, nothing else happens. The light comes on 4x4 but that all i get, If i press the low range button i dont get lights or clicking..Is this a motor problem? I just got this truck and im not sure what it is supposed to look like or do. Any suggestions?...Joe
Old 12-21-2009, 08:44 PM
1975StroppeBaja
Again... info from me applies directly to my '94 Explorer and I'm assuming Ford used the same general setup for their F150s. From the responses above, it seems like they did.
Usually if the 4x4 light comes on, that means the t-case has engaged properly. Only thing in question then is the hubs unless they are manual. To get it to go into low range, you'll need to be stopped with the transmission in neutral. You should hear a pretty solid "thunk" when it goes into low range.
Hope this helps.
4x4x4x4
1999 to 2016 Super Duty
01-13-2003 10:35 PM
4x4x4x4
28
12-16-2002 01:54 AM
4x4x4x4
12-01-2002 03:02 PM
4x4x4x4
Modular V10 (6.8l)
11-05-2002 01:53 PM
4x4x4x4
08-13-2002 09:43 PM
Quick Reply: push button 4x4 not working on 93 F150
