Sponsored by: Real Truck
ABS/cruise control problem
Old Dec 29, 2002 | 06:46 PM
4x4x4x4's Avatar
4x4x4x4
Old Jan 12, 2003 | 08:36 AM
glcarpe's Avatar
glcarpe
Post ABS/cruise control problem
I have a 1999 2WD F250. The truck is a crew cab and has the V10 with 3:73. I am experiencing an intermittant problem with the ABS and cruise control. I am not sure they are related but seem to both happen at the same time. The ABS light will come on (steady light) once truck get moving (approx 20 + MPH). If the ABS light is on, the cruise will not work either. No ABS light, the cruise appears to work OK. I have never seen this problem till it got cold out here in KAnsas. Some days this problem does not happen, other days it does. Please give some advise if you can! (Rear wheel ABS only)
Old Jan 12, 2003 | 09:23 AM
NoMo's Avatar
NoMo
Don't know why Ford linked the two features, but they definitely are related. Sounds like you need a new ABS controller. Before spending mega-$$$ at Ford, you might check around at a few salvage yards. Be sure to get one for RABS vs 4-wheel ABS.
Old Jan 12, 2003 | 11:35 AM
charlesvalentine's Avatar
charlesvalentine
I had the same problem along with the speedo not reading speed until about 15-20mph. The problem started with symptoms like your and progressively added new symptoms then the tranny started shifting funny. It was the speed sensor over the rear diff. about $11 and 10 minutes work to replace, fixed it.
99 F250SD EC 5.4L 3.73 285 BFG/ATs...
99 Expy EB 5.4L
Old Jan 13, 2003 | 09:52 AM
bddo's Avatar
bddo
>replace, fixed it.
>99 Expy EB 5.4L
Charles is right... Had the same problem.. Dealer wanted $200 to replace the rear speed sensor. Paid $14 for the part, took 10 minutes to install, and went to AutoZone and had them clear the code. (Mine had already triggered the Service Engine Soon light)
Bryan
2000, F250CC, V10 Auto, Lariat, maroon/black, grille guard, Ventvisors, woodgrain dash kit, aftermarket fog lights, K&N air filter,fender flares, Rancho 9000x shocks
Future Mods: Rancho steering stabilizer, flowmaster 40 exhaust, acetoned emblems.
Old Jan 13, 2003 | 08:23 PM
4x4x4x4's Avatar
4x4x4x4
In this case,I would "throw" a part at it and see what happens.The part I'm referring to is the vehicle speed sensor in the rear axle.
Old Jan 13, 2003 | 10:35 PM
glcarpe's Avatar
glcarpe
Thanks for the info. This forum is a nice resource! Is this a part that must be ordered from Ford?
664x4drvr
Mar 3, 2026 08:14 AM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
4x4x4x4
Dec 1, 2002 03:02 PM
killer4x4
Mar 9, 2001 06:49 AM
hotrodford_88
Feb 1, 2001 11:38 AM
