auto window down switch
Old Dec 12, 2009 | 09:55 PM
mrsdbro's Avatar
mrsdbro
I'm just wondering if anyone has done this or even if it can be done. install an auto down window switch for passenger front door in the frt. pass. door itself or/and in driver door panel. is there a knowledgeable tech who is familiar about these switches? are the switches interchangeable? An installer from the local autoglass shop told me that in the auto down mode, that what stops the window motor is the window when it bottoms out and the motor stops because of the heat generated when the motor stops turning. I don't know if its that way, I just want to install the auto switches if they'll work. I noticed the Lincolns have auto up and down, would these switches work? Just looking for something different to do.
Old Dec 12, 2009 | 10:39 PM
Franklin2's Avatar
Franklin2
I don't believe you can do it with your regular stock driver's side switch. Looking at this diagram(2005), the driver's side switch with the auto function is a all in one unit with all the master controls contained in it.
AutoZone.com Repair Guide Image
I believe the glass installer is correct, the switch works somewhat like a circuit breaker, detecting when the motor stalls and draws a lot of current.
Old Jan 15, 2010 | 10:09 PM
lmd91343's Avatar
lmd91343
It's been done on '04 - '08. I've read about several, even an '07 CC with all four window.
try this, second item down: PonyPerformance.com~ One Touch Down window module kit
I've down both doors on my '89 with first item.
Old Jan 15, 2010 | 10:26 PM
Franklin2's Avatar
Franklin2
Good info, thanks.
Old Jan 17, 2010 | 01:38 PM
mrsdbro's Avatar
mrsdbro
Ditto on the info. it looks like it would do the trick.
teamlx88
May 21, 2015 08:30 AM
pathfindertango
Feb 20, 2015 01:20 PM
teerex
Nov 11, 2013 08:30 PM
jdguest
Jan 19, 2011 05:39 PM
farmallh
1983 - 2012 Ranger & B-Series
Aug 20, 2009 04:05 PM
