2wd vs 4wd headers
Old Dec 11, 2009 | 01:19 PM
Ford150/428/dud's Avatar
Ford150/428/dud
2wd vs 4wd headers
I can get some stainless FE 2wd headers for cheap. But my truck is a 79 F150 4wd, 428FE.
Has anyone ever attempted to fit the 2wd headers on a 4wd. Im pretty sure they will hit the drive shaft or the T case will be in the way.
Does anyone have any input on this?????
Old Dec 11, 2009 | 08:55 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Not sure on the 2WD to 4WD, but 4WD headers WILL NOT work on a 2WD.
But that is in reference to Dynomax and Hedmans. Not sure about Hookers, Thorley's or any other breed like that.
Josh
Old Dec 11, 2009 | 11:05 PM
Ford150/428/dud
Thats the thing these are OBX headers each brand varies for fitment. I have a 4 inch lift in the front so I do have more drive shaft clearance than a stock 4wd.
The frames are similar with the 4wd actually having no crossmenber under the motor.
I can imagine that they would quite possibly clear Im just looking for any ideas and real life situations.
Old Dec 11, 2009 | 11:14 PM
Bullitt390's Avatar
Bullitt390
I would think the 2WD header would be pointed straight at the transfer case. It's a tight clearance with the C6, with just 1/2" space between the collector and the shift arm.
Josh
Old Dec 12, 2009 | 12:05 AM
Ford150/428/dud
Thats what I was thinking and then I would have to prababley run a exhaust tube under the trans to connect to the passenger side.
I just got done looking things over and theres not much play room, so I cant imagine fitting a preformed header that's not meant to fit.
Old Dec 12, 2009 | 06:57 AM
frdavid's Avatar
frdavid
Summit sent me 2WD headers for my 4x4 TWICE. Didn't work either time.
Old Dec 14, 2009 | 11:53 AM
ell Header's Avatar
ell Header
I dont if u want stainless there used mostly for show cars. Ive heard that L&L sells some nickle plated headers u should check them out.
www.landlproducts.com
mean351stang
Jan 17, 2016 11:58 AM
F250fordtruck
Aug 18, 2015 09:21 PM
jeff80
Sep 1, 2012 08:20 PM
73 ford guy
Jul 5, 2011 01:20 AM
bigtymer77
Mar 20, 2007 09:59 AM
