1978 - 1996 Big Bronco
Ignition key!!
Old Dec 10, 2009 | 11:19 PM
jimford1's Avatar
jimford1
Ignition key!!
Why the F@#K does my ignition turn super hard when it is cold??? WTF?? I was turning it over with two hands tonight! Can I fix it??
Old Dec 11, 2009 | 01:12 AM
greystreak92's Avatar
greystreak92
With a little heat (start the truck and warm up the cabin really well) and some graphite. Never use any type of petroleum-based lubricant on the keyswitch or any lock mechanism for that matter. If you get into the mechanism and find such lubricants you will most likely find a very sticky mess since petroleum products thicken when cold. You can clean a sticky mechanism with a penetrating lube but follow that up by wiping it off and adding the graphite right away. That way when the penetrating lube that gets left in there dries up it leaves the graphite behind to do the lubricating.
Old Dec 11, 2009 | 06:44 AM
helirich's Avatar
helirich
The actual contacts are way down the steering shaft. (by your feet) Sometimes it gets tight down there. You may try some lube there also. Look for binding on the rod that goes between.
legoman0234
Apr 3, 2014 07:13 AM
harbor97
Nov 10, 2013 05:19 PM
RAGaz
Sep 20, 2010 09:40 PM
zagnut1972
1997 - 2003 F150
Oct 26, 2005 06:30 AM
nyunicorn
Dec 15, 2003 06:40 PM
