Sponsored by: Auxito
Stuck Ignition
Old Apr 25, 2005 | 03:10 PM
zagnut1972's Avatar
zagnut1972
Stuck Ignition
I have a 2001 F-150 XLT V-8, I drove my truck twice yesterday and when I was about to head to town yesterday I put the key in and nothing. I cannot turn the ignition. I tried to move the steering wheel back and forth, tried pushing on the brake, tried cleaning the key and ignition, tried everything I can thing of. However my key will not turn the ignition, and yes I know it is the right key. Never ever had this problem before but the dang key just will not turn the ignition in any direction. PLEASE HELP.
Old Apr 25, 2005 | 05:18 PM
Latintiger's Avatar
Latintiger
I have a '98 f-150 and that has happened to me before. I was told that all you had to to do was turn the steering wheel, but even my steering wheel was stiff and wouldnt turn. but i kept trying and soon enough i was able to turn my steering wheel and let me turn my iginition.
Old Apr 25, 2005 | 07:57 PM
peppermrj's Avatar
peppermrj
If you can turn the steering wheel and the lock cylinder still does not turn, chances are it is toast. Try turning it hard in both directions first tho.
http://www1.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0a/9e/94/0900823d800a9e94.jsp
These are instructions for removing it with out the benfit of a key for trucks up to 96. I would recommend checking a manual for your year. Wouldn't want an airbag in the face.
Did one in an old mustang by drilling out the tumbler starting with a small bit and going progressivewly larger. again no air bag!
Good luck and let us know
Old Oct 23, 2005 | 05:27 AM
Choach's Avatar
Choach
99 Ford Expd EB 77K. Same problem. From one moment to another the ignition did NOT work.
Turned Key all you hear is relays clicking but thats it. Found 15A ignition fuse under dash blown. Replaced tried ignition again & fuse blew again. Checked all ground OK. Checked Starter OK. Battery OK. The only way to start the car is by bridging the starter solenoid underneith the car with a pair of pliers.
This is dangerous do not recomend anyone doing it unless you realy know what your doing. Not good for your car either. Anyone please help?
Old Oct 23, 2005 | 08:25 AM
HomerWinzlow's Avatar
HomerWinzlow
Choach, what fuse number is it? Need to know what circuit is shorted. Is the fuse at the fuse box or to an alarm system?
Old Oct 24, 2005 | 04:36 AM
Choach's Avatar
Choach
Smile
No alarm system. Interior fusebox. I bleive it is 21 or 22. It is listed as ignition in the owners manual. If you have a solution please let me know. My truck is at the mechanic & I can avoid repair charges he wont look at it until tuesday. Thanks.
Old Oct 24, 2005 | 06:24 AM
HomerWinzlow
Looks like the DTR sensor on the transmission circuit. This is often caused in this vehicle by a harness on the passenger side rear of engine compartment that has fallen down onto the exhaust manifold and burned through and the wire is shorting on the manifold or egr tube.
Old Oct 25, 2005 | 05:49 AM
Choach's Avatar
Choach
Question
You are 100% right on the button. It cost me $120.00 for this info & a temp fix from the mechanic. The wire harness is hidden in between the tranny & manifold. Very narrow space very hard to see. An ignition wire on the harness burned & was causing the short. I wish I had gone to this forum before I took it to the mechanic could have saved $120. I became desperate. The mechanic suggest harness be replaced. $800 to $1000. Dealer may be responsible since they replaced the tranny on warranty 5/2004. The wire harness was not fastened on the tranny. Mechanic said other wires in the harness could have been damaged but didnt. Any suggestions?
Old Oct 25, 2005 | 06:22 AM
HomerWinzlow
Yeah, he is out of his mind. Ive repaired that little burn for a couple hours labor many times. No more than 3. Looks like you found a parts replacer. Hell he didnt even have to search for the problem.
Old Oct 26, 2005 | 02:01 AM
Choach's Avatar
Choach
Unhappy
HomerWinzlow. I am humbly in need of your advise. What would you sugest. The Mechanic said he would complete the repair for $200 more. Currently all he did was push the harness away from the manifold for $120.
Old Oct 26, 2005 | 06:30 AM
HomerWinzlow
What is the Labor Rate at your local dealer? Our rate is 65.00 per hour. Some areas are a lot more than SW Oklahoma. So 200 may be reasonable or outrageous. If its a lot less than a dealer will fix it then you have to decide if he has been reasonable or you would rather trust the dealer.
The repair often only requires removing the inner fender well on the RH side and getting enough slack to splice the wires with new wire and rewrap. On rare occasion you may have to disconnect from transmission and feed out the harness far enough to repair it. That is considerably more time intensive. I cant see the damage so I dont know how far he needs to go, but I see absolutely no reason to replace the harness under normal circumstances.
banshee_man_96
Nov 22, 2018 07:20 AM
V8SHO
Dec 17, 2015 05:41 PM
86f250xl
Large Truck
Apr 2, 2015 06:15 AM
2011F-250KR
6.7L Power Stroke Diesel
Feb 25, 2015 10:13 PM
jayro88
Apr 18, 2014 06:43 AM
