Tail signal bulbs interchangeable? 3057-4057
They are interchangeable and will not create any problems. There is a 2 or so, watt difference between the 3057 and the 4057. The 4057 has the higher output.
As long as you're replacing a S8 Wedge lamp with one from the same family, it will fit and work just fine. In other words, 3057 works in place of a 4057 or a 3157 in place of a 4157. Personally, I would stay with the correct wattage when ever possible, but if you're bulb fails and you can only get the lower wattage one, it will get the job done.
Go with a Sylvania replacement if you can. When I was an engineer working in the S8 Wedge production area, our lamps had longer lamp life then any of our competitors.
The short of this, a 3057 will be just fine
iRockFosgate
41
11-24-2017 05:37 PM
2008, 3057, 4057, bulb, bulbs, difference, expedition, f150, ford, interchangeable, lights, rear, signal, spec, tail
