Sponsored by: Real Truck
Outside mirror bulbs
Old Apr 6, 2016 | 10:03 AM
BCM's Avatar
BCM
What type bulbs are in the outside mirrors? The running light in particular. I have one that is intermittent... I'm assuming the turn signal bulb in the mirror will be the same. AutoZone says they are a Sylvania 194, but I just wanted to verify here first.
Old Apr 6, 2016 | 10:06 AM
wrvond's Avatar
wrvond
They are both 2825.
http://shop.advanceautoparts.com/p/s...5-ll/5080130-P
Old Apr 6, 2016 | 10:16 AM
BCM's Avatar
BCM
Thank you. Looks like the 194 is the same as the 2825? No Advance Auto Parts around me, so it would have to be Auto Zone.
Old Apr 6, 2016 | 10:35 AM
wrvond's Avatar
wrvond
#2825 Miniature Bulb Glass Wedge Base - 12 Volt 0.4 Amp 4.8 Watt T3-1/4 Glass Wedge Base 4.0 MSCP, C-2R Filament Design, 300 Average Rated Hours. 1.06" (26.80mm) Maximum Overall Length, 13/32" (10mm) Maximum Outer Diameter. 0.50" (12.70mm) Light Center Length (L.C.L.).
#194 Miniature Bulb Glass Wedge Base - 14 Volt 0.27 Amp 3.78 Watt T3-1/4 Miniature Wedge Base, 2.0 MSCP, C-2F Filament Design. 2,500 Average Rated Hours, 1.06" (26.80mm) Maximum Overall Length, 13/32" (10mm) Maximum Outer Diameter. 0.56" (14.20mm) Light Center Length (L.C.L.).
While they are physically interchangeable, it looks to me like the 194 will not burn as brightly.
Old Apr 6, 2016 | 10:36 AM
BCM's Avatar
BCM
I knew you guys would know. Thank you!
Old Apr 6, 2016 | 12:35 PM
254XP3's Avatar
254XP3
Just replace them with 194 LED's. Simple swap and I like them better illumination wise and sharper on/off.
Old Apr 6, 2016 | 06:41 PM
Jaime74656's Avatar
Jaime74656
looks like 254XP3 beat me to it, but anyways just put LEDs in (if coloured lenses make sure you use the colour matched LEDs, if clear just what ever colour(s) you want) and be done with them...I am switching over to LEDs as my bulbs burn out...
Old Apr 6, 2016 | 07:47 PM
BCM's Avatar
BCM
Saw his post too late. I found an Advance Auto Parts here in town and they had the 2825s. All set for now. I like the LED idea for when I have some extra cash to replace all four.
Midwest Dually
6.4L Power Stroke Diesel
Nov 9, 2013 01:28 PM
f350duallyguy
Feb 5, 2013 03:52 PM
gsxr1300
6.7L Power Stroke Diesel
Feb 16, 2012 09:43 AM
cshaak
Jan 5, 2008 11:54 AM
brow603
1997 - 2003 F150
Sep 1, 2007 04:14 PM
