Engine exchange
Old Dec 5, 2009 | 04:56 PM
hypetyme's Avatar
hypetyme
Engine exchange
Will a 302 bolt right into my 72F100 without any modifications? Also, the existing inline six has a C4 XMSN. Can I mount the C4 onto the 302 without modifications, and if not, what do I need?
Old Dec 5, 2009 | 08:09 PM
marks69's Avatar
marks69
probably motor mounts.
gl
mark
Old Dec 5, 2009 | 08:18 PM
RoughIdle's Avatar
RoughIdle
You will need motor mounts and stands for the 302. As far as the transmission you will need a different bell housing I think.
Old Dec 5, 2009 | 08:27 PM
85e150's Avatar
85e150
302 V8 and 300 six share bell pattern.
Flex plate must be correct for your 302. See the top of the SBF forums for flywheel/imbalance info.
Shift points may need to be fiddled with.
Don't forget exhaust, cooling--you may find the hoses are on different sides. Linkages, fuel lines, little things.
Old Dec 5, 2009 | 08:51 PM
RoughIdle's Avatar
RoughIdle
[quote=85e150six4mtod;8207757]302 V8 and 300 six share bell pattern.
I did not know they shared the same pattern. I learned something new today. Now I hope I can remember this. Lol
Old Dec 6, 2009 | 05:13 AM
carpenter547's Avatar
carpenter547
hey rough idle my brother has that set up you want. if you need or want i could take pics of it as it sits right now.
Old Dec 6, 2009 | 05:37 AM
first today's Avatar
first today
The 351 windsor also uses the same bell housing and exhaust manifolds as the 302.
Old Dec 6, 2009 | 06:11 AM
jowilker's Avatar
jowilker
The 300 & 302 share the same bell bolt pattern. They use different engine perches. The 302 perches from 68-79 also are shared with the 77-79 351/400M.
The 302 will need to be fitted with the proper to year 302 engine flexplate.
The accelerator cable is different in length, the 300 is several inches longer than the 302.
I believe the radiator hose setup is different also.
The C4 should work fine behind the 302.
John
dthomas620
Feb 20, 2011 11:07 AM
royrooster79
Jan 20, 2010 05:31 PM
confederate_mudder
Offroad & 4x4
Jun 6, 2007 10:06 AM
the original
Dec 12, 2003 10:56 PM
tallica2002
Nov 6, 2002 08:07 PM
