Compression Test Results
Old Dec 5, 2009 | 02:23 PM
qcy2k6's Avatar
qcy2k6
I just completed a compression test on my 1997 F250HD 351 and my results are as follows:
1=145, 2=150, 3=145, 4=145, 5=120, 6=150, 7=150, 8=145
I have white smoke and steam coming from the tail pipes that’s why I did the compression test. What is the diagnosis? Before this problem I had a bad FPR and it was allowing fuel into the #8 cylinder and causing the motor to Hydro lock.
Old Dec 5, 2009 | 05:20 PM
85e150's Avatar
85e150
Do you also have fuel contamination and grayish color and bubbles in the coolant?
Head gasket seems the likely culprit.
Old Dec 5, 2009 | 06:33 PM
qcy2k6's Avatar
qcy2k6
No fuel or grayish color in the coolant. However it was super low.
Old Dec 5, 2009 | 10:38 PM
Beanscoot's Avatar
Beanscoot
Do you have antifreeze in the radiator? If so, and if it is coming out the exhaust, you will be able to smell the sweet smell.
Old Dec 5, 2009 | 10:43 PM
qcy2k6's Avatar
qcy2k6
I did have coolant in the radiator. It is now gone, not all gone just low. I ran the truck for a bit to warm it up before the pressure tast and did not see any wite smoke / water in the tail pipes. I did in the past smell what you were talking about.
Old Dec 5, 2009 | 10:55 PM
Beanscoot's Avatar
Beanscoot
I worked on an Escort this summer that had this intermittent white smoke problem. Most of the time it was fine, every once in a while huge clouds of white smoke poured out behind the car.
It turned out the (aluminum) head was cracked between the valves in two cylinders. Often the cracks would be clogged with the usual coolant sediment, but when the engine got hot or when there was a lunar eclipse, the crack(s) started to open and allow coolant into the chamber and whoo boy, smoke screen.
I had to change the head, but with cast iron heads usually the heads don't crack, the gasket just fails.
Old Dec 5, 2009 | 11:15 PM
qcy2k6's Avatar
qcy2k6
At first I thought you were telling me you were a escort. LOL!!!
Yep... I think if I filled the coolant back up the smoke would start again. Yes tons of white smoke so much it looked foggy outside.
Old Dec 6, 2009 | 12:36 PM
Beanscoot's Avatar
Beanscoot
Yeah, my friends call it the "Prostitute Car".
Old Dec 9, 2009 | 11:01 AM
rockher_man's Avatar
rockher_man
Lightbulb Oh boy...
...bummer...stop runnin' it man...it will only get worse...take the head to a
"good" cylinder head shop...IF it ain't too poo-poo'd...they "should" be
able to bake-it straight...weld-it-up...check it out...and...
... you'r good-to-GO-man-GO...
Been there done that...I had one with 4 cracks once that I had
repaired 'cause at that time I did not have the scratch for a new
one and it lasted years...
Old Dec 9, 2009 | 12:02 PM
daveengelson's Avatar
daveengelson
Not an authority, certainly would not drive until problem is solved. Seems compression on all cylinders are within spec's, and did not find any coolant, or water in oil. It's rare but wonder if it's possible the fuel pump diaphram could be leaking. Anyhow, just a thought.
Old Dec 9, 2009 | 01:14 PM
qcy2k6's Avatar
qcy2k6
Not driving the truck, has no coolant in the oil, the pump is in the tank. Got a leak down tester just need the time to do the test.
Old Dec 10, 2009 | 03:31 PM
Beef Stew's Avatar
Beef Stew
Try a leak down test. A compression test only tells you so much.
Old Dec 10, 2009 | 05:00 PM
Kemicalburns's Avatar
Kemicalburns
if the head is cracked just get another wrecking yard E7 head. would be cheaper then having the cracked one fixed.
Old Dec 10, 2009 | 05:25 PM
lew52's Avatar
lew52
X-2 just get another head ,i have two sets of E 7 heads that i can't give away ...
Old Dec 10, 2009 | 06:37 PM
qcy2k6's Avatar
qcy2k6
Yep...
I got the leak down tester just need the time to run the test. I will let you know
Thanks
John Rowe
16
Mar 18, 2023 04:46 PM
06FUN
Oct 29, 2016 07:53 AM
Slomoe
Dec 12, 2013 06:06 PM
lakerats
Mar 17, 2011 02:40 PM
qcy2k6
Dec 6, 2009 11:14 AM
