Do I need Head Gaskets?
Old Dec 5, 2009 | 09:11 PM
qcy2k6's Avatar
qcy2k6
I just completed a compression test on my 1996/7 F250HD 351 and my results are as follows:
1=145, 2=150, 3=145, 4=145, 5=120, 6=150, 7=150, 8=145
I have white smoke and steam coming from the tail pipes that’s why I did the compression test.
What is the diagnosis?
Before this problem I had a bad FPR and it was allowing <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_2_0>fuel</NOBR> into the #8 cylinder and causing the motor to Hydro lock. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Dec 5, 2009 | 09:13 PM
Argo's Avatar
Argo
I would do a cylinder leak down test next.
Old Dec 5, 2009 | 09:59 PM
qcy2k6's Avatar
qcy2k6
What will a cylinder leak down test tell me that a compression test does not? I have to buy a leak down tester thats why I am asking?
Old Dec 5, 2009 | 10:16 PM
1OldFordMan's Avatar
1OldFordMan
White smoke / steam is a sign of coolant in the cylinder. Does sound like a head gasket problem, but I'd wait for somebody else to answer your question instead of taking my word for it. It wouldn't be the first time I've been wrong. The white smoke / steam part I'm sure about. The head gasket, probably, but not a 100% guarantee. Thought a head gasket would cause two cylinders next to each other both to be low.
Old Dec 5, 2009 | 10:23 PM
qcy2k6's Avatar
qcy2k6
Originally Posted by 1OldFordMan
White smoke / steam is a sign of coolant in the cylinder. Does sound like a head gasket problem, but I'd wait for somebody else to answer your question instead of taking my word for it. It wouldn't be the first time I've been wrong. part I'm sure about. The head gasket, probably, but not a 100% guarantee. Thought a head gasket would cause two cylinders next to each other both to be low.
I thought that at first also... However cant the gasket fail between the water jacket and only one cylinder? If the gasket failed between 2 cylinders I should not have he white smoke / steam. correct?
Old Dec 5, 2009 | 10:45 PM
1OldFordMan
Not sure about that, I'd wait for somebody else to answer that one.
Old Dec 6, 2009 | 07:21 AM
Argo's Avatar
Argo
A leakdown test will pump compressed air into the cylinders. This will tell you the leakdown rate of the cylinders. Also, the compressed air will make locating the point of leakage easier. You can look for and listen for compressed air leaking from the intake, exhaust, crankcase, and cooling system. That would help you identify a cylinder head leak, or determine that the coolant is getting into the cylinder by another means (I.E. a leaky intake or EGR cooler plate). If your engine is consuming coolant, but you don't get compressed air bubbles from the cooling system while doing this test, it is likely that something in the intake is your culprit, not the head gasket.
Old Dec 6, 2009 | 07:30 AM
Linemo's Avatar
Linemo
couple of things are you losing coolant also oil in your crankcase also look for white gunk around your dipstick
Old Dec 6, 2009 | 11:14 AM
qcy2k6's Avatar
qcy2k6
Oh... That sounds good I will get one
BLADE35
Nov 25, 2012 09:06 PM
tags1970
1983 - 2012 Ranger & B-Series
Mar 5, 2010 06:17 PM
qcy2k6
Dec 10, 2009 06:37 PM
Rooster368
Dec 6, 2009 07:47 PM
AZ_Turbo
Aug 28, 2009 11:52 PM
