Sponsored by: Real Truck
Intermittent Battery Light
Old Oct 11, 2010 | 11:43 AM
lakerats's Avatar
lakerats
Last 2 or 3 weeks, the battery light on the instrument panel has been coming on occasionally. It might stay on for 2 seconds - at other times maybe two minutes (or longer). Can't seem to find a pattern here.
A week ago the light stayed on all the way home from work (about 45 minutes).
I have not driven the truck for about a week.
Yesterday, I had to charge both “new” batteries sine each was down to about 5 volts. Not surprising if they're not charging since I have an inverter that runs 24/7 (I've pulled the fuse).
<O></O>
1. Cranked it up 30 minutes ago, checked voltage on both and found 12 volts only.
2. Checked Alternator output and initially no voltage.
3. Re-checked batteries and found 14.2 volts.
4. Re-checked alternator - found 14.2 volts
5. Opened the door to check if bat light was on – no light.
6. Rechecked the bats – “0” (zero volts)!
7. Rechecked the alternator – no voltage.
8. Checked the bat light – it was now ON!
9. Rechecked the bats – 14.2 volts
10. Rechecked the bat light – now OFF!
<O></O>
What the heck is going on? Alternator? Computer? Something else?
<O></O>
Thanks in advance to the forum.
<O></O>
Clif
Old Mar 17, 2011 | 01:44 PM
yamahonda41's Avatar
yamahonda41
Intermittent battery light
Hey did you get this figured out. I am having same problem on 2006 6.0.
Old Mar 17, 2011 | 02:01 PM
tjc transport's Avatar
tjc transport
i ain't rite
two things could cause this to happen.
1: loose or bad plug on the alternator.
2: failing alternator.
Old Mar 17, 2011 | 02:13 PM
jh818's Avatar
jh818
This happened on my Excursion a while back. Changed the alternator and it was fixed.
Old Mar 17, 2011 | 02:40 PM
yamahonda41
Thanks guys. I guess 95k miles is about the life!
ten.mile
May 16, 2020 04:34 PM
06FUN
Oct 29, 2016 07:53 AM
ten.mile
Dec 11, 2012 05:56 PM
lakerats
Electrical Systems/Wiring
Dec 8, 2010 08:00 AM
lakerats
18
Oct 16, 2010 09:10 PM
