old school db2 tricks
Adjust that screw out, same 25% throttle and the smoke rolls black.
You adjusted the fueling curve to throw more fuel to the engine at lower RPM.
To much smoke at low RPM, turn the screw in, smoke at low RPM decreases.
With a little experimentation, you can get a light haze of black across most of the RPM range by balancing the internal and external screws on a turbo engine.
Takes lots of little adjustments to get it just right.
It don't change how much pressure or fuel the IP puts out.
All that changes is the internal IP pressure, which changes the timing and timing advance.
On a test bench is the only place you can get that one right.
It's not a torque screw. It's a low RPM fuel limit.
The only thing it effects is the amount of low rpm emissions You produce. ie: smoke. We don't need any more enviro ****'s coming for out older trucks.
I have found a lower internal setting and turning the external screw out can give a bit more power down low and still keep the smoke down.
If you have the internal screw turned in several flats, then turn the external screw out a couple turns, power goes down and smoke increases to the extreme.
Small adjustments to both screws, drive it.
It takes time to figure out where both need to be set for the best results.
IP condition, injector condition, your elevation, turbo condition/boost level and the condition of your engine make this a different setting for every motor.
Stanadyne has two settings, regular and high altitude.
Most of us do not live where either those settings would be optimal.
Can't wait to fire it up when I get home. I think I'm going through withdrawl after being away from that clatter for so long.
Did you decide to get moosed? My only problem with it is it only turns just barley 3000rpm i just couldnt live with that
But yes, thats what I decided on. I can get 10+ PSI smoke free by 2500 RPM and hardly ever go to 3000 RPM. Considering my tall gearing I simply don't need higher than 3000 anyway. I might have some slight tweaking to do on the transmission computer for the lower governed speed.
Honestly it was the more thorough rebuilding that sold me on them. What I learned about rebuilt pumps is that they are a lot like rebuilt engines. Doing it right takes a lot more than doing it well enough that it will run. Tighter pumps have more steady fuel/timing curves, and that means better MPGs. From what I read, the hot pumps tend to get good economy when cruising and thats what I'm after. If I could, I would have rebuilt it myself, but I can't. At least not yet, so this time around I will fork out the money.
Locally I could have spent about the same for a bone stock remaned pump so it was a no brainer. Nice guy here in town, but he doesn't like the idea of custom work so I gave up going to him.
Guess I could have gone for a "baby moose", but c'mon, would you settle for that on a studded turbo IDI?
Even if it gets a mere 0.5 MPG better then it will pay off fairly quick even with the higher price.
well you may finally get to hit 20 psi
, no actually you probly dont, unless your fine with scatterin your motor eveywere, which i am still yet to do, btw did you see my high rpm run video?
