removing pulley from ps pump
Old Jul 22, 2012 | 05:37 PM
jeff14346's Avatar
jeff14346
Hi
How in the bleep do you remove the pulley from power steering pump? 73 f250 cs, I see the large allen head retainer, cant get it to break loose, I damged the pulley, looking also for another pulley
Thanks
Old Jul 22, 2012 | 06:24 PM
mikeo0o0o0's Avatar
mikeo0o0o0
It takes a special puller. The regular jaw type puller doesn't work.
The correct puller grabs the groove machined into the center hub.
EDIT:
The shaft depends on the press fit between the shaft and pulley to keep the pulley in place. There is no other set screw, bolt or anything that keeps the pulley in place.
To reinstall, place pulley on the shaft and place 2 or 3 flat washers over the shaft. Take a bolt that will thread into the end of the shaft, not 100% sure but I "think" it's 3/8"-16NC. Screw a nut onto the bolt and then screw the bolt into the shaft. Hold the bolt from turning with one wrench and tighten doen the nut with the other bolt untill the pulley hub is flush with the shaft. Unscrew bolt and remove washers.
NOTE: Be sure to install the pulley with front of the pulley facing out....I've seen 'em istalled backwards before, then there's no way to remove them.
Old Jul 22, 2012 | 06:25 PM
mikeo0o0o0's Avatar
mikeo0o0o0
What engine, w or w/o a/c?
Old Jul 22, 2012 | 08:07 PM
jeff14346's Avatar
jeff14346
yes that may be helpful!!
fe390, no ac
thanks for the reply back
Jeff
Old Jul 22, 2012 | 08:55 PM
Blue and White's Avatar
Blue and White
Autozone has the pull/press tool for the PS pulley on "loan a tool". I used one to swap the pulley for my Dent and it worked fine.
Old Jul 22, 2012 | 09:11 PM
jeff14346's Avatar
jeff14346
Thanks for all the feed back guys, very helpful!!!!
Jeff
Old Jul 22, 2012 | 10:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
fe390, no ac
Jeff
Here's what the Ford parts catalog says
Pulley, power steering pump
73-76 F100-350 w/ 360-390
Marked #7AA
C7AZ-3A733-A
Last list price $56.62, dealer cost $33.97
Dennis Carpenter Obsolete Parts, Concord, NC has 3 (704) 786-8139
Green Sales, Cincinnati. OH has 4 (800) 543-4959
Mustangs, Etc., Van Nuys, CA has 6 (818)787-7643
There are several more out there if you need more names.
One thing that puzzles me. When I installed factory A/C on my own '73 w/a 360 the power steering pulley was different. The parts catalog only lists one pulley and says nothing about w/ or w/o A/C.
Look at your old pulley, there should be an ID number stamped on it. According to the catalog it should be #7AA. If it's a different number let me know and I'll see if I can cross it over.
Not really super clear but in the first picture was the non-a/c pulley. It "dishes" out. The second pic is the A/C equiped pulley. The offset "dishes" in. Which one does yours look like?
Old Jul 23, 2012 | 07:48 AM
jeff14346's Avatar
jeff14346
Mike
Mine is the first pulley, I picked up a pump from the yard which was an a/c equipped vehicle, and pulleys dont line up, I was able to bend the pulley back, I closed the gap where the vbelt rides in, after I remove the pulley will check further to see how it "rides". I will let you know if I need your pulley, please let me know what you are asking for it, shipping to 93637
Jeff
Old Jul 23, 2012 | 08:33 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Mike
Jeff
Jeff, I don't have that pulley anymore. I did the conversion a couple of years ago. Look at my previous post, if you do need a pulley check for #7AA stamped on the pulley. If that number is stamped on the pulley, any of the suppliers I listed have it (13 between the three that I listed). If that's not the number stamped on your pulley, post the number and I'll see if I can cross it over and locate one for you.
Old Jul 23, 2012 | 02:57 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7AZ-3A733-A .. Single Sheave P/S Pulley-stamped #7AA / 5 1/4" O.D. / Obsolete
Applications: 1968/76 F100/350 360/390 ~ With/without A/C makes no difference / Misc: 1967/80 Ford/Merc Passenger Cars.
Mike, if your P/S pump (steel reservoir) didn't have this pulley, a PO either changed the pump or the pulley, probably came from a car.
Old Jul 24, 2012 | 11:14 PM
jeff14346's Avatar
jeff14346
got the pulleys swapped from one unit to the other, rented a puller from autozone worked like a champ. was able to pursuade my original pulley with a hammer and a 3/8 drive extension to correct vbelt alignment
my pulley was stamped with 6AA, the other unit from the ac truck
was marked BOAR - BI, no 6 or 7 AA. got it back together and running, pulley looks good, going to run it and see how it does.
Thanks again for the input and feed back
Jeff
Old Jul 25, 2012 | 12:13 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Old Jul 25, 2012 | 07:55 AM
NumberDummy
My pulley was stamped: 6AA, the other unit from the ac truck was marked D0AR-B1 = C9TZ-3A733-D
6AA = C7AZ-3A733-E ~ 1967/72 F100/350 & misc 1960/70's Passenger Cars only.
Old Mar 23, 2013 | 03:11 PM
250-Ranger-390's Avatar
250-Ranger-390
FYI, my psp also has the Allen bolt that won't break loose on the pulley. That's what brought me here.(maybe original and most are just missing this cause it isn't needed) I'm about to look for a new pulley and turn the old one in with the core.
Old Mar 23, 2013 | 04:22 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you're referring to the center of the shaft having a hex shaped hole, that doesn't have anything to do with retaining the pulley on the shaft. The center of the shaft is tapped (IIRC 3/8"-16).This is used when the pulley is both removed and installed.
There is only a press fit that retains the pulley. There is no drive key either, it is a smooth shaft.
To remove the pulley you have to use a tool like the one pictured in post #2. You screw a bolt into the center of the shaft. Use that tool to clamp around the groove that's machined into the pulley hub, then screw the forcing screw down. This will push against the bolt in the shaft (you use a bolt so the forcing screw won't damage the threads of the bolt hole). As you tighten, the pulley will come off.
To install, get a long bolt, some flat washers and a nut. Screw the nut on to the bolt as far as it will go, then the flat washers and the pulley. Screw the bolt into the shaft. Align the pulley with the shaft and tighten the nut. As you tighten, it will force the pulley onto the shaft. Tighten until the pump shaft is flush with the outside hub of the pulley.
BTW welcome to FTE, lots of good people here.
