ZF5 Tranny fluid
Old Dec 1, 2009 | 06:06 PM
Jimmy Mac's Avatar
Jimmy Mac
ZF5 Tranny fluid
I have a ZF547 5 speed
I run the Mercrun synthetic ATF in it
I'ts a professional freshly rebuilt Tranny.
It's kind of loud
What type of other fluid could I run in it, I've heard of Royal purple and even straight 30 wt motor oil
Also I have a growling noise around 1000rmp when costing under no load,give it gas or push in on the clutch and it goes away
The old tranny made the same noise at the same RPM
I do have a South bend clutch and solid flywheel in it
Thanks
Old Dec 1, 2009 | 11:42 PM
85e150's Avatar
85e150
Have the trans man listen to that noise. Heavier oil isn't the best answer if there is a problem somewhere in your drivetrain.
Old Dec 2, 2009 | 04:25 AM
Lazy K's Avatar
Lazy K
Is this a diesel where the dual mass flywheel has been swapped for a solid one?
Old Dec 2, 2009 | 04:32 AM
Jimmy Mac's Avatar
Jimmy Mac
Yes the daul mass was swaped for a solid flywheel
It made the noise with the old tranny and a different solid flywheel,so I swaped everything out and still have the same noise
Old Dec 2, 2009 | 07:31 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/7...heel-help.html Have a read through this thread. ZF5 noise is common after fitting a SMF to a diesel. The noise you had before may have been due to a bad DMF.
Old Dec 2, 2009 | 08:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The reason the dual mass existed in the first place was to eliminate this noise that you're hearing. You are always going to have that noise with a single mass flywheel.
idisam6.9
Sep 23, 2016 10:08 PM
pdqtimetrialer
Dec 28, 2012 09:33 AM
Daltonsheets1995
Nov 27, 2012 01:20 AM
martinez53
Jan 16, 2011 04:56 PM
BGFNRED
Aug 16, 2005 07:03 PM
