Oil Cooler How To...since it's that time of year.
#91
#92
#93
You may end up sacrificing more than a quart. I ended up pouring a gallon and a half through before I stopped seeing any trace of ELC in the oil. Since I couldn't guarantee I didn't get oil in the rear passages, too, I ran an entire sacrificial oil/filter change through it, then filled it up with normal oil and sent a sample to Blackstone after a test drive. Results aren't back yet.
If I had it to do over again, I'd drain the radiator (which I did), drain through the heater element (which I did), and drain the driver's side block from the drain port (which I didn't). I might even consider carefully pouring oil back through the *oil* ports while the cooler is off, so to get any coolant out of those passages.
Oh, if your water pump has the removable elbow on the inlet port, removing that makes those front bolts trivially easy to access. You'll want to replace that gasket, and probably use some RTV on it, as they are prone to leak.
Mark
Mark
#94
#96
Mark
#99
Oil cooler / heat exchanger 02 F250 4WD
I just finished an oil cooler re-seal this past weekend. It took a few hours to do the job. The front top bolt was easily removed with extensions through the wheel well. The front bottom bolt was easily removed from below the truck. I removed the front wheel. The three rear bolts are accessed from below using the 10mm ratchet but can be accessed via long extensions through the side of the frame. I suggest a scotch brite pad for cleaning the stainless o-ring seats along with dry paper towels. Oil cooler was removed from the engine towards the rear then down below. It was installed within an inch of the engine, then after installing the front top bolt through the cooler, I hung the front gasket on the bolt, then installed bolt to the engine loosely. Aligned gasket with bottom front hole then installed bottom front bolt in that order. After this, I installed the rear gasket and three bolts and torqued.
Hope this helps,
Vern
As seen through tire well
Hope this helps,
Vern
#101
#102
Getting water in the pan is still a concern, but not nearly as bad as coolant.
jrockdiddy
12-11-2012 10:41 PM
DarkNite
09-15-2009 04:43 PM
