Trouble Codes
Old Dec 3, 2009 | 03:14 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by jk_hooper
So interestingly enough the plug on the tail housing of the tranny wasnt plugged in good. That cleared up my tranny code.
Did this also clear up your shifting problem?
Old Dec 3, 2009 | 09:36 PM
jk_hooper's Avatar
jk_hooper
Yes it did. I do have a different shift pattern though. It doent go into OD at 40 like before. Is there a difference on the 01 shift pattern? I know my old PCM was XLE4. My new one is totally different. I will post its code tommorrow.
Old Dec 3, 2009 | 11:44 PM
PaysonPSD's Avatar
PaysonPSD
I am still running an XLE4 but have a couple of PMT1s. I have been told that the shifting will be different if I install a PMT1, but different how I don't know? With the XLE4 I hit OD at about 45.
Old Dec 4, 2009 | 12:20 AM
twags6's Avatar
twags6
I have an 01 and my trans shifts into OD between 40 and 50 depending on how hard i'm on it. If you're on it really hard, it will hit 3rd, then OD, then lock the T/C. The T/C will stay locked in OD until you drop to 38 and locked in 3rd until 28. It locks the T/C differently when you have 4wd engaged. I'm still trying to figure that out.
Old Dec 4, 2009 | 06:04 AM
jk_hooper's Avatar
jk_hooper
Mine is hitting OD about 50-52 when driving normally. If i push the pedal its like 60 something or a littl more. I have a PMT3 now. I am likeing it for daily driving but have not towed anything yet.
Old Dec 4, 2009 | 09:03 AM
jk_hooper's Avatar
jk_hooper
I rechecked this morning. I have P0238 (boost) and P1211 (inj press) which i know is consistant with the TS. I am going to hopefully going to get my buzz test done over the weekend. I am still getting the IDM code P1316.
Old Dec 4, 2009 | 10:37 AM
ggirten's Avatar
ggirten
We need to check the wiring connectors on the valve covers. It sounds like hopefully you may have an injector connector not plugged real well.
Hackerdcd
Apr 26, 2015 09:57 AM
vegtoph
Dec 6, 2014 12:11 PM
pilgrimbizket
38
Aug 4, 2013 08:46 PM
DragnBotm
Jun 19, 2006 05:40 PM
