Trouble Codes
Old Nov 27, 2009 | 05:06 PM
jk_hooper's Avatar
jk_hooper
Trouble Codes
I have my 2001 motor in my early 99 truck. I swaped out the PCM. I am getting two codes. P0720 and P1316. I know the P1316 is from the IDM so i checked and the guy said i can have the IDM on the 01 truck. Can any one give me a reference to pull the IDM, pics? Also what would cause the P0720 tranny code?
Thanks for the help in advance.
Old Nov 27, 2009 | 06:54 PM
F350-6's Avatar
F350-6
The IDM is up inside the drivers front wheel well above the liner, tucked back behind the F350 badge. Scott has done a write up with pics on how to mod the IDM, but it includes removal which should work for you. 2001 Ford F250 4x4 - IDM mod pictorial
Old Nov 27, 2009 | 07:04 PM
tdpower's Avatar
tdpower
re
The 1316 just means there are codes stored in the idm and you have to do a buzz test to retrieve them. Often times this is caused from one of the 9 pin plugs under the valve covers that tends to come loose. What is the truck doing? Not sure about the 720 code.
Edit: If swapping the motor is a recent thing maybe it is a wiring issue?
Old Nov 27, 2009 | 08:19 PM
ggirten's Avatar
ggirten
P0720 is the output speed sensor on the tail housing of the tranny.
Old Nov 28, 2009 | 12:54 AM
jk_hooper's Avatar
jk_hooper
Thanks fo the info guys. I will get the IDM Monday and swap them.
I just got the engine put in. Starts and Runs great. I get a SCS light as soon as i get on the pedal very hard. These are the codes it gives. Also my tranny isnt shifting properly. It is like it delays the shoft or doesnt want to shiftg at all. I tried my 99 pcm and my 01 pcm. Not any different with the shifting.
PS: I did put the quarters under the VC on the plugs. I will double check the outside plugs though. I cannot buzz test them but if swapping the IDM doesnt fix it i will see about getting them buzzed at a local shop.
Old Nov 28, 2009 | 02:35 AM
mueckster's Avatar
mueckster
What are you using to do the buzz test? With the AE, you will need to set it for the '01 year model. Early '99 PCMs weren't capable of doing the buzz test, but it should be able to with the '01 installed. Also, the E'99 has a 110v IDM and the '01 is 120v, giving it a slight upgrade, too.
Pull the Output Shaft Speed Sensor and check for any metal sticking (not necessarily a good sign) to its magnet. This may be causing some sensor signal issues. The PCM compares the input and output signals to determine gear ratios/shifts of the trans.
Old Nov 28, 2009 | 09:01 AM
Visseroth's Avatar
Visseroth
My E'99 can run a buzz test just fine. I know, I've done it a few times
Old Nov 28, 2009 | 09:37 AM
mueckster's Avatar
mueckster
My bad. I was posting late last night and was thinking of the Rotational Velocity % readings. I need to get more rest.
Old Nov 28, 2009 | 11:51 AM
Visseroth's Avatar
Visseroth
Really? So the never rigs give you this reading?
Old Nov 28, 2009 | 12:02 PM
mueckster's Avatar
mueckster
Yes. When accessing the drop down menu for the live data meters, you can select the rotational velocity % reading for each cylinder. I tried to do this on an early '99 and couldn't get the data. I found out later this was due to the differences in the PCMs. If you have a later model PCM installed and set the AE for that year, it should bring up this data.
Old Nov 28, 2009 | 04:27 PM
jk_hooper's Avatar
jk_hooper
So interestingly enough the plug on the tail housing of the tranny wasnt plugged in good. That cleared up my tranny code. IDM will be installed Monday evening.
Thanks for the info guys. Very informative as always.
Old Nov 28, 2009 | 08:40 PM
Visseroth's Avatar
Visseroth
Huh? I'll have to toy around with that but in doing so what is this information going to tell me?
Old Nov 28, 2009 | 09:02 PM
mueckster's Avatar
mueckster
At idle a perfect balance of all the cylinders will show 0% on all eight (not common). Percentage #s above 3% show a cylinder(s) that is(are) not firing as well as the others. This is similar to the Cylinder Contribution Test that cancels cylinders, one by one, electronicly and then give a code for the weak cylinder(s), if found.
Old Nov 28, 2009 | 09:08 PM
Visseroth's Avatar
Visseroth
huh, maybe I'll do some dinking around think weekend with it. To bad I don't have anyone near by that knows how to read these things better then I do.
Old Dec 3, 2009 | 02:48 PM
jk_hooper's Avatar
jk_hooper
I have replaced the IDM. I tried clearing the codes with an AutoTap. It showed clear until i drive it a little hard and let off the pedal. they come back. I will try to get it on a better computer in the next day or so. I will let you guys know what i find.
