Aerostar Ford Aerostar
Aerostar suspension question???
Old Nov 23, 2009 | 09:14 AM
Emilime75's Avatar
Emilime75
Well, 2 questions really. I have a 97 2wd extended Aerostar XLT. My rear springs are sagging when it isn't loaded. I use it for work so I often need to lug tools and materials, and I also tow a boat with it in the summer. I bought new shocks for it and would like to replace the springs as well. I am considering purchasing springs for the AWD version of this van. From what I have read on Amazon is that both springs have the same ID, the same installed height and are made from the same diameter steel. However, the spring rate for the AWD spring is higher than the spring rate for the 2wd version. I will probably also install the Air Lift 1000 kit for heavy loads.
Can anyone tell me if the AWD rear spring will fit without modification on a 2WD Aerostar? The springs I am considering are Moogs, models CC841 and CC845.
My second question, does any one know the stock ride height for the front of a 97 Aerostar, extended 2WD XLT with a 4.0 and auto trans? I am wondering if I should replace the front springs as well. I am considering Moog CC850's for the front.
Old Nov 24, 2009 | 08:22 PM
aerocolorado's Avatar
aerocolorado
Someone correct this if wrong, but I believe the extended models used the same rear springs whether 2WD or 4WD versions. Front springs are completely different. You will need to either replace your rear springs or else level the body before trying to do ride height comparisons. Obviously, a sagging rear end will elevate the front end. Rear spring replacement is fairly easy. The lower spring pan bolts are usually corroded and will snap off but do not require any special type of fastener.
Old Nov 25, 2009 | 08:39 AM
KhanTyranitar's Avatar
KhanTyranitar
On an extended, they should both be the same. For the record, I used Moogs, and they were disappointing. They rode no higher that the old worn out springs. I have to use airbags just to level it out.
Old Nov 25, 2009 | 05:06 PM
aerocolorado
I replaced my rears with Husky brand and ride height is correct but the quality of the spring is somewhat less than OEM.
Old Nov 25, 2009 | 05:55 PM
taurus8's Avatar
taurus8
I replaced mine with ones from the junkyard from a low mileage van...handling has never been better.
KhanTyranitar
Aerostar
53
Aug 31, 2013 08:34 PM
Dentedvw
Feb 18, 2013 02:11 PM
vacman
45
Sep 15, 2012 07:05 PM
95XLT
Aerostar
13
Feb 2, 2006 08:41 AM
97Aero
Aerostar
13
Sep 9, 2003 12:32 PM
