97-01 short blocks Interchangeable?
Old Nov 24, 2009 | 09:11 PM
  #31
fordzilla01's Avatar
fordzilla01
Originally Posted by Quick444
From what I recall the gasket has to match the front cover. So if you swap everything from your 01 engine, use the gasket from that engine. It should be the one with the metal screen in it.
If you are building over everything on literally just a short block, it should rebuild exactly the same.
In my case I threw in a 97 Longblock and thus had to do a ton of part swapping.
In you case just move everything you already have over. Its truly simple if you take your time as you tear it apart. I couldn't believe it.
This is my plan as my motor only had 200,000KMS on it. I am "Planning" on building a complete shortblock from one of the motors I am picking up, and moving my heads and EVERYTHING else onto the block with rods/pistons/crank.
The machine shop said that they recommend NOT pulling the frost plugs as the new ones don't always fit correctly. Any comments on this?
Thanks,
Old Nov 24, 2009 | 09:40 PM
  #32
Quick444's Avatar
Quick444
Thanks,
Frost plug? I believe that is what we call a freeze plug but I could be wrong. I would say that it isn't worth worrying about. They can be a huge pain in the *** to deal with and there isn't a sense in fixing what isn't yet broken!
Old Nov 25, 2009 | 10:15 AM
  #33
fordzilla01
Ya the only problem is that usually when you have the block hot tanked, it takes out the Cam Bearings and the Frost plugs.
I'll have to see weather I end up using my block or one of the two that I have arranged to pick up.
Old Nov 25, 2009 | 10:35 AM
  #34
Ponyboychris's Avatar
Ponyboychris
Like any engine rebuild, if you hot tank the block, it has to be bare including freeze plugs and all bearings. Double check your heads also. If you did some carnage to the rods and pistons in your older engine, make sure no pieces came up and kissed the valves or combustion chambers. Just a precaution. I would also change out the glowplugs and check all wiring harnesses for wear as well. This has been an informative thread. Good luck and post up pics and updates!
Old Nov 25, 2009 | 10:44 AM
  #35
mongo75's Avatar
mongo75
Hey this might help you out, or at the very least give you a laugh or two- engine removal
I
Old Nov 25, 2009 | 03:05 PM
  #36
fordzilla01
Cute... The beer is correct so far...
Old May 7, 2010 | 01:06 PM
  #37
chrisallo's Avatar
chrisallo
ok so i did the same swap with my 2001. i left the single shot injectors in it with the 2001 computer. now how do i change the computer to get all of this to play together? I can't find any place that has some kind of chip to swap in to the 2001 computer to control the single shots. HELP!!!
Old May 7, 2010 | 01:43 PM
  #38
CSIPSD's Avatar
CSIPSD
Hummmm I would hope you did not leave the little AA injectors and 15* hpop in the motor. That would be a huge step back.
All you need to run single shot injectors is a chip. Thats easy. But you dont want AA injectors in a superduty.
Old May 8, 2010 | 02:49 AM
  #39
homesteader's Avatar
homesteader
Originally Posted by PowerstrokeJunkie
97 engines seem to be correlated to staying together at very high horsepower. Not that you'll ever get there but Marty is around 800 hp on nitrous based on trap speeds, and is putting in injectors right now that should put him into the 10's, (~950hp) at least for one pass, on a stock bottom end. Just head studs push rods and valve springs. mmmmmmmm
So mean the 97 engines are stronger than the 99-00 engines? Iam thinking of doing the same swap? Who's Marty?
Thanks
Old May 8, 2010 | 02:53 AM
  #40
homesteader
Thanks,
Is your truck done looks like its been a while?
Old May 9, 2010 | 11:14 AM
  #41
fordzilla01
Yes, all is done and running solid. (FINALLY). All the problems I experienced were stupid things like frost plugs that werent installed correctly from the Machine Shop & A crack in the oil plan I used... But looks like its all good now... I have about 1200miles on it so far and I am VERY happy.
Old May 10, 2010 | 02:03 AM
  #42
homesteader
How much hp are you getting with the setup you have listed?
Old May 10, 2010 | 11:53 AM
  #43
fordzilla01
Haven't had a chance to do a true dyno, but I am told around 500/1000Ft
Old May 10, 2010 | 07:31 PM
  #44
Maintain's Avatar
Maintain
Thanks
I'm Marty
Old May 16, 2010 | 02:27 AM
  #45
homesteader
Originally Posted by Maintain
I'm Marty
Okay Marty thanks now I know who you are on FTE.
kenworth01
Mar 12, 2015 06:48 AM
rhymesconnie
1997 - 2003 F150
Jul 13, 2014 08:59 PM
gtmustang00
1983 - 2012 Ranger & B-Series
Mar 18, 2013 07:35 PM
FrankeeD
Mar 12, 2013 01:49 PM
1997FORDF150
1997 - 2003 F150
Apr 19, 2004 06:01 PM
