Sponsored by: Real Truck
Oil pan removal
Old Nov 21, 2009 | 06:21 PM
99 F-250's Avatar
99 F-250
Oil pan removal
My 1999 F-250 5.4 is leaking oil and i was going to try and replace the oil pan gasket. I read in the Haynes manual that i have to raise the engine. I was wondering if i really had to do this. If i do is there a new pan i can get that i wont have to raise the engine again. Thanks for any help you can give me
Old Nov 21, 2009 | 06:26 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Unless you cut the crossmember below it, then yes, you have to lift the engine. If it helps any, for the 7.3 you pretty much have to completely pull the engine out... Are you sure it's coming from the block/pan junction, and not the dipstick area? On the 7.3s, the dipstick can get to leaking pretty good.
Old Nov 21, 2009 | 09:43 PM
99 F-250's Avatar
99 F-250
Alright im pretty sure its not coming from there but i will look thanks for the help
Old Nov 21, 2009 | 11:21 PM
Slick2's Avatar
Slick2
it's a big job, I passed on buying an 99' F350 because the oil pan was rusted out, my friend at a ford dealership said it was a 9-10 hour job for guys who have done it before.
Old Nov 22, 2009 | 12:10 AM
Furian's Avatar
Furian
You Keep What You Kill
Come on, you've got to be kidding me... the engine has to be pulled to replace the oil pan? What "engineer" came up with that design???
Old Dec 5, 2009 | 06:09 PM
99 F-250's Avatar
99 F-250
I would think you could do it with out pulling the engine but there is a crossmember that is in the way of taking it off easily.
Old Dec 5, 2009 | 06:16 PM
Slick2's Avatar
Slick2
Dealership said you need to lift the engine, don't think it technically has to be pulled but it does need to be lifted a bit.
Old Dec 5, 2009 | 06:30 PM
99 F-250's Avatar
99 F-250
Ya i was just hoping i wouldnt have to because that will take some time
UncleTom
Oct 7, 2016 08:38 PM
bigcrunch
Aug 31, 2016 09:16 AM
chincycoot
Aug 30, 2013 06:47 AM
mr.fordneck
Apr 17, 2012 11:01 AM
wingham
21
Apr 19, 2003 07:37 PM
