ok im wanting to hook up a manual oil pressure, voltage, and water temp guages on my truck its a 2000 f350 with a 7.3 were is the best place to hook all these guages up at?
For the Water Temp gauge, I used the port just below the T-stat housing on the waterpump - it points to the driver's side. It's a pipe plug IIRC. The voltage gauge I just found a key-on 12volt source. In my case, behind the passenger side kick panel, there is a large plug for the overhead console that had a key-on wire. Both work just fine.
Oil pressure gauge sensor goes in a port in the rear-driver's side of the block. Kind of up where the trans bell housing bolts up. I'll see if I can find a pic...
EDIT: Here you go. It's the rectangular plug in the bottom of the pic.
i just got a new phone and have not got it set up for all the pic stuff il post them when i get it figured out. does anyone have a better pic of were to hook up the oil pressure guage?
