water temp guages
Old Jun 14, 2004 | 10:52 PM
Josh79's Avatar
Josh79
water temp guages
i was driving my 79 f 150 4x4 with a 400 2 days ago when i noticed that the water temp guage was not working. It was as low as the guage goes. so i figured the sending unit went bad or the guage and i already have a seperate gauge cluster with a water temp guage in it. i was going to hook it up in place of the stock one and i messed with the stock sending unit then drove my truck to go get some things before hooking up the new guage. i then realized the stock guage was reading fine and read like it normally does. i was curious if there was any way to hook up both the stock and the aftermarket water temp guages up just incase the stock guage was messed up or acted up again. if not i will probaby hook up the aftermarket guage alone to be safe. i realize that the 400 has a dry manifold so i assume that you cannot hook up two guages but thought i would double check.
Old Jun 14, 2004 | 11:36 PM
Mil1ion's Avatar
Mil1ion
I'm sure that a T-connection or coolant source could be attached to.
Moving to the electrical forum.
Old Jun 15, 2004 | 11:05 AM
Josh79's Avatar
Josh79
could i hook up the extra water guage to the thermostat housing? i notice there is a plug there in the top of the thermostat housing. also there is one on the top left of the water pump. would that work either?
Old Jun 15, 2004 | 11:18 AM
ford390gashog's Avatar
ford390gashog
yes you can just unplug one of those and put in a after market mechanical one like i did it works well
mavman4
Nov 19, 2019 04:03 PM
77429highboy
Aug 2, 2011 09:32 PM
KICKEDBACK
Jul 31, 2011 12:49 PM
priv8pilot
Jul 20, 2006 10:36 AM
Hank79
Dec 27, 2003 01:08 AM
