In addition to your probable vacuum leak and AC clutch adjust, the other common problem with our AC's is the fact that ford has the system set up so the heater core is always on. Your air box has a simple flap valve to direct the air over AC coil or heater core or a mix of two.
You can buy a valve (itp has them) that goes in-line with your heater hose and config it so that when you go to max AC the heater core no longer receives hot coolant. This worked for me.
Not sure why you need Ac right now but glad to hear that you do !
alright im glad im not the only one thinking who in the world is diagnosing a/c problems in the middle of november! i dont really have anything to add just being a little ornery....
