wheel studs?
Old Nov 15, 2009 | 03:04 AM
ktm747's Avatar
ktm747
wheel studs?
my 67' f250 has alot of sheared off studs and i have no idea how to get to them or how to get them off. its stock so its got drums on it
Old Nov 15, 2009 | 03:26 AM
Skip1970's Avatar
Skip1970
hammer is your friend
Old Nov 15, 2009 | 04:23 AM
jowilker's Avatar
jowilker
Agree with B, grab a hammer and wack em. Don't be afraid to hit em, you can't hurt em.
John
Old Nov 15, 2009 | 10:03 PM
ktm747's Avatar
ktm747
now how would i take the drum off
Old Nov 16, 2009 | 12:19 AM
Ford_Six's Avatar
Ford_Six
Pull the whole hub. All the 67-72 F250s I have dealt with had the drums mount to the back of the hub, clamped on with the studs.
Same with the rear, but you have to pull the whole axle shaft out.
Old Nov 16, 2009 | 02:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Once you remove the studs from the hub, they should not be used over again.
The studs have raised serrations on the hub end. The serrations retain the hub to the brake drum. Once studs are removed, the serrations flatten out.
If reused, the drum will not fit tight to the hub, which means the drum will eventually walk away from the hub.
The correct way to remove wheel studs is with a press. You may be able to remove them with a hammer, but when installing new studs, they should be pressed in.
This is how all Ford Dealers, and brake shops do it.
Brentmez45
2009 - 2014 F150
Nov 5, 2016 05:02 PM
SgtRauksauff
Apr 12, 2016 09:50 AM
Buyerz
Aug 10, 2015 03:44 PM
jmd1060
Exhaust Systems
Apr 21, 2009 11:33 AM
riverrat07
18
Apr 5, 2007 05:53 PM
