Body Side Moulding
I figure the general idea of it is to install the spring loaded threaded stud and nut thingys into the holes, and slide the fragile looking tan plastic clips over the studs on the fenders. right? Whats the best way to actually position/lay out all these holes so when I drill them, they end up kind of straight? What about the studs on the doors and bedsides, how to I go about getting those on, or an alternative to having them? Thanks!
In terms of straight lines, use masking tape in combination with a flexible ruler and a waterbased marker.
You can get your paint guy to paint you some chrome and black strips in that dent and even race trac trim.
Check these folks out. http://cgfordparts.com/wwwsectionfil...e_molding.html
bedsides dent clip positions: front of bedside to front of wheelwell is all plastic clips, then one hole for a stud/clip to go through that you then have to put the nut on from the backside of the fender, it is possible just awkward, either 11/32 or 5/16 nut, 11/32 is original ford size and 5/16 is aftermarket if I remember right. then from that stud/clip it is all plastic clips until in front of rear marker light I think (I will have to consult photos to check). Then for the vertical curved racetrack piece you will need 3 holes drilled through bedside for 2 stud/clips and one push-trhough metal clip in lower corner.
bedside lower racetrack molding: I will have to consult pics later, i think there were 11 or 16 attachment points. I know it uses 3 different styles of clips: the small plastic clips for the factory studs that are missing, the push-through style metal clip, and the stud/clip that will need a nut put on from the backside(i think there are 3 of these, 1 ahead of wheel well and 2 behind it). The push-through style clips were only used above the wheelwell and I think ford used 6 or 8 of them.
And if I remember right there was approx 14" vertical space between bottom of dent molding and top of racetrack molding at the front of the box (the rear of the box has that wraparound vertical racetrack piece), OR 14" of space between holes I drilled for moldings. Pretty sure it was between edges of moldings
Last edited by four-sixty-power; Aug 10, 2015 at 12:44 PM. Reason: added: "at the front of the box..."
Sand all the paint or primer off in the dent where you need to put the studs & drill the holes. Measure half way across the dent at each end of the panel, make a mark. Run a straight edge between those marks, & make a few more marks. Run a long length of masking tape between the marks to connect them. Mark where you want your studs & holes. I recommend drilling the holes with what is called a bullet bit. It has a small center drill, with cutting edges to give you the hole size. It makes a much cleaner hole than a standard drill bit. I welded all the studs on with a stud attachment on a handheld welder normally used for welding pull studs on to sheet metal to pull out dents. It worked really well after some practice on some scrap fenders. Then prime & paint. Make sure you paint the back of the panel too, rust will want to start everywhere a stud was welded or a hole was drilled.
No way I would rivet the clips on, that is inviting rust!!
It wasn't as hard as I imagined it would be, just a little time consuming. It looks great now that it is done, everything lines up fine & looks straight.
