Custom Zoodad
Old Nov 15, 2009 | 06:12 PM
  #31
YoungMT Hick's Avatar
YoungMT Hick
ok just doing one for one.
Old Nov 15, 2009 | 06:41 PM
  #32
1975StroppeBaja's Avatar
1975StroppeBaja
Looks like you guys got it all under control
One thought though if you're struggling with the correct resistor/LED setup and you only have 1k ohm resistors, you can connect two 1k resistors in parallel with each other, that will give you 500 ohms which is very close to the original 496ohms you needed. You would use a total of four 1k resistors but it would get the job done.
Don't forget the pics once you're done!
Old Nov 15, 2009 | 06:46 PM
  #33
69cj's Avatar
69cj
Ya and no offense to anyone but I didn't want to muddy the waters.
Old Nov 15, 2009 | 07:27 PM
  #34
YoungMT Hick
ya its cool just takes a little hammer out. thanks
Old Nov 15, 2009 | 08:31 PM
  #35
1975StroppeBaja
For the future searchers of this thread, here's a quick schematic I drew up of the two scenarios discussed above...
Old Nov 15, 2009 | 08:34 PM
  #36
YoungMT Hick
Extreme dissatisfaction with Radio Shack LEDs. 6.3 mcd does NOT give off a very strong light. Barely visible. Project is on hold until I can find better LEDs Does anyone know a store where I can get brighter LEDs??
Old Nov 15, 2009 | 08:43 PM
  #37
1975StroppeBaja
http://www.superbrightleds.com/
Old Nov 15, 2009 | 11:07 PM
  #38
YoungMT Hick
just loooked on there found the 8000 mcd 45 degree green led. need to find more lights to get from them 5 for shipping so i want to get like tailights and turn signals before i just get two led's. so are those led's going to be good enough and what other bulbs can i get from there. thanks good site
Old Nov 16, 2009 | 11:14 PM
  #39
ncbondsman's Avatar
ncbondsman
LED Circuitry tutorial: how to hook up LEDs.
That is the site I used when I did an LED project on a TS Chip Switch. It tells you everything you need to know (and it has pictures). There are links to resistor calculators as well.. Hope this helps you out...
Old Dec 7, 2009 | 04:56 PM
  #40
YoungMT Hick
Smile Finish
Ok so now i got the ZOODAD done how i want. and have time to finish my write up. ok so what i had to do was order some new led's off of superbright leds . com. i got the 8000mcd at a 45 degree angle pattern got four and only have two installled. here is some pics:
kinda THE SETUP OF WHAT I HAD kitchen counter top a walmart soldering iron and led holder from radio shack and 16 ga wire
first attempt using two resistors found out dont try and do the math and get them in paraller or series just get the closest resistor ohms you can for what you need. so i got a set of 5 560 ohm resistors when i need 505 ohm's
finished product
so this is what i finished up with.
for all those that havent followed this thread.
zoodad mod in cstom shape using a dremel
wired up a set of two green 8000 mcd led's
cut in to the amber lighs (parking lights) for power
whenever the amber's have power these will so even whenyou lock your truck it flashes. kinda cool. any one have questions willing to help
Old Dec 7, 2009 | 05:23 PM
  #41
jamie7375's Avatar
jamie7375
Very nice....
Old Dec 7, 2009 | 05:35 PM
  #42
BigRy's Avatar
BigRy
Awesome, I was just thinking of doing a regular zoodad, might go a different route now with a custom design.
Old Dec 7, 2009 | 05:37 PM
  #43
YoungMT Hick
ya i saw al the people that just cut the hoels and left it at that. i mean you can do alot of things with a dremel. **** could of cut the ford symbol out. i just figured more flow is better than no flow so i didnt need that gapping whole in my grill
ZooDad
All Other Items for Sale
Aug 31, 2015 01:09 PM
brettdacosta
63
Jan 12, 2015 06:22 PM
ChrisCarter
Nov 30, 2012 07:38 AM
tkill
Jan 19, 2012 10:56 AM
sharethewealth
16
Mar 8, 2010 02:42 PM
