ok so tapped into the driver's side amber side light for power and am using the existing ground near the back of the headlight. had to pull the headlight to get to those amber lights didnt know that. so i have power have a ground, drilled holes for the two led's, now going to solder the resistors to the positive side cover them in shrink wrap then connet them in parallel to the power and ground them in parallel, question i could only get 1K ohm resistors would it be better to run one resistor in series than running two resistors in parallel when i only need 496 ohm per led? or is that cutting it
No, resistors in series are additive. In parallel if resistance is the same for each resistor it is halved. If more than 2 resistors in parallel the formula is;
ya i was but is that to much or can i do that thats what i am asking dont want to know numbers what do you think i should do just want the help sorry
Two parallel leds calls for 248 ohms. one led calls for 496 ohms.I think that one 1,000 with one led will work. If not you can always change the resistor but the calcs. would call for a 500 ohm. Main thing is resistors are cheaper than leds. Incidentally, if using two led's use a one watt resistor. Single led will be OK with a 1/2 watt resistor.
