6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Intermittent Cruise Control Function
Old Nov 11, 2009 | 11:10 AM
jmcbrid's Avatar
jmcbrid
I have a 2008 F250 - Job 1 with intermittent cruise control function. Occasionally when I turn on cruise and hit set, it does not come on no matter how many times I push on and set (at or above 30 - 35 mph). Much of the time I can shut my truck down and restart and cruise will work, but not always. Once it is working - I can turn off cruise and restart it and it always works. If I turn my truck off there is a chance the cruise will not start. Anyone have a similar problem?
Old Nov 11, 2009 | 04:19 PM
senix's Avatar
senix
sounds to me like the contacts on the buttons may need cleaned. Any chance you have taken the buttons off and checked the contacts?
Old Nov 11, 2009 | 05:29 PM
ZeroOne's Avatar
ZeroOne
Yeah, almost sounds like the "ON" button isn't connecting well. If that didn't work, no matter how many times you press "set", it isn't going to listen, without seeing "ON" first.
On second thought... there was some electrical reason for cruise not working that someone else had posted. Possibly on another forum. Is everything else on the truck working properly? No odd behavior?
Old Nov 11, 2009 | 07:42 PM
jmcbrid's Avatar
jmcbrid
No other issues or problems. I'm half thinking it is a switch issue or a sensor problem. I took it to the dealer today and they immediately pulled the steering wheel switch. In the past, without fail if the cruise did not work I could shut off the truck and it always would work. Since they pull the switch today - I have only been able to get it to turn on once - no matter how many times the truck has been shut down and re-started. I have an appointment tomorrow to have them hopefully figure out the issue. I'll post the solution.
Thanks for the replies
Old Nov 11, 2009 | 07:47 PM
RoadJunkie's Avatar
RoadJunkie
I would tend to look at the interlocks that are required to be satisfied prior to the cruise control working, e.g., brake or clutch engagement. Perhaps the brake light contact switch is intermittent or maladjusted and will not allow the cruise to become engaged?
Old Nov 12, 2009 | 02:35 PM
jmcbrid's Avatar
jmcbrid
Just got back from the shop. Ended up being the Brake Pedal Pressure switch. Looked to be an easy fix. Everything seems to work fine now.
Old Nov 12, 2009 | 02:57 PM
69cj's Avatar
69cj
If I remeber correctly the brake pedal sw. is now a press. sw. on the brake cylinder in the engine comp.
Old Nov 12, 2009 | 08:24 PM
jmcbrid's Avatar
jmcbrid
What I understand is that it was in the engine comp and next to the master cylinder.
Thanks
Old Nov 17, 2009 | 06:35 AM
capt caper's Avatar
capt caper
I have had the same problem. I keep thinking its me or the weather. When I turn it on I am careful of how I press the ON side. This has seemed to help but I'll keep an eye on this post to make sure it keeps running in time.
Old Dec 19, 2009 | 01:39 PM
fx4superduty33's Avatar
fx4superduty33
sounds fimilar. I had the same issue over the summer. First the dealer replaced brake switch, it worked than 500 miles later it quite again. Went back to the dealer, it took them all day to diagnose it as a second brake switch, they replaced it and it has worked so far, im sure glad i bought the extended warranty
EightySecond
Oct 27, 2019 12:52 PM
gebweb
1983 - 2012 Ranger & B-Series
15
Feb 9, 2017 04:36 PM
tspangle84
Vehicles for Sale
Dec 12, 2016 09:12 AM
bpounds
S. California Chapter
Oct 26, 2016 09:06 PM
Bill Payne
Dec 23, 2013 01:55 PM
