C8AE-H HEAD SPECS.
Old Nov 11, 2009 | 08:43 AM
1969CamperSpecial's Avatar
1969CamperSpecial
C8AE-H HEAD SPECS.
I checked the FAQ first!
I picked up a set on Craigslist that have been rebuilt with hardened seats.
Looking for "as cast" combustion chamber and head height specs (gasket surface to top of head bolt hole)
I'm trying to determine if the heads have been milled
The valves are 2.2 intake and 1.65 Exhaust.
Thanks in advance!
Jon
Old Nov 11, 2009 | 10:56 AM
1969CamperSpecial
Opps... had those valve sizes all wrong!
Intakes 2.02
Exhaust 1.55
2.2 woud be a neat trick involving rewriting the basic laws of physics!
Old Nov 11, 2009 | 11:59 AM
Kennewick's Avatar
Kennewick
This should be a shop drawing of a similar head. Hope it is what your looking for.
1969 Ford Fairlane pictures7 picture | SuperMotors.net
Old Nov 11, 2009 | 12:01 PM
Kennewick's Avatar
Kennewick
I hope this what your looking for.
PS now the post shows up. Sorry for the duplicate.
Old Nov 11, 2009 | 12:22 PM
1969CamperSpecial
This is exactly what I was hoping to find Thanks!
Old Nov 11, 2009 | 03:13 PM
Bear 45/70's Avatar
Bear 45/70
Combustion chamber volume is 68 to 71 cc
Exhaust valve 1.56".
Intake valve 2.04"
Intake ports 1.34" X 1.93"
Exhaust Ports 1.28" X 1.94"
Old Nov 11, 2009 | 07:32 PM
Redmanbob's Avatar
Redmanbob
The tell tale of milling is seen in the thumbprint area. Lower right hand corner of this pict. IIRC unshaved this is about a .040 offset. And usually the milling leaves an obvious diagonal swirl across the face that can been seen at the right angle.
1972fordhighboy2
Apr 12, 2017 07:03 AM
parker757
1947 and Older Ford Trucks
Mar 2, 2016 08:28 AM
BadDogKuzz
Feb 14, 2012 01:01 PM
64F-100
Nov 5, 2008 06:38 AM
spidermonkey
May 14, 2008 10:50 PM
