Engine Torque specs
Old Mar 1, 2016 | 02:16 PM
parker757's Avatar
parker757
Engine Torque specs
I Recently removed the head off of my inline 6 flat head (g series) I have looked around and can not seem to find torque specs for this engine. Does anyone know where i can find them?
Old Mar 1, 2016 | 04:42 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Chart dated 12/6/40 for the 2GT truck engine. Torque is 180 lb/ft at 1200 rpm. HP is 90 at 3300 rpm. Source is the 1946 Dealer Handbook. Stu
Old Mar 1, 2016 | 04:49 PM
michael a's Avatar
michael a
Stu, I think he is wanting to tighten the head. Are those 1/2 or 7/16 head bolts, or studs?
Old Mar 1, 2016 | 04:52 PM
truckdog62563
Oh yeah, duh. Need one of the guys that has a service manual. Stu
Old Mar 1, 2016 | 08:49 PM
Rickster800's Avatar
Rickster800
According to the G Series Engine Repair Manual I have the cylinder head torque is 50-60 lbs. Not sure why the 10 lb range. Instructions include starting at the most centrally located nut and tighten alternately from side to side.
Old Mar 2, 2016 | 06:59 AM
parker757's Avatar
parker757
Thank you maybe tighten them as patterned to 50 then take them all to 55 and see if it holds. They a 7/16 studs i would like to replace them as well but can not seem to find the right ones for my engine
Old Mar 2, 2016 | 08:13 AM
michael a's Avatar
michael a
I would suggest cleaning the studs good with a thread chaser.
Old Mar 2, 2016 | 08:28 AM
parker757's Avatar
parker757
If I can not find replacements I will run a die over each stud and a tap through each nut but sound advice with stuff this old. I think i have had to chase 90 percent of the treads on this truck so far
Binder Guy
3.8 & 4.2L V6
Jun 16, 2017 03:58 PM
oldtexasdog
Sep 22, 2011 10:09 AM
robbi
1997 - 2003 F150
Nov 24, 2007 09:37 PM
John - NNY
Flathead V8 & Flathead 6
Apr 26, 2006 08:55 AM
Gooch
1978 - 1996 Big Bronco
Feb 6, 2004 07:36 PM
