Frame coating
Old Nov 2, 2009 | 01:43 PM
Blown 331's Avatar
Blown 331
I just painted my frame. I didn't do anything fancy but my truck rarely even sees rain so I'm sure it will last a long time. I pulled the bed and set it upside down. Six of my bed bolts came right out, I had to cut two of them. Then I just took a wire wheel on a grinder to the bottom of the bed floor and all over the frame, axles, springs, bottom of cab etc, etc. Then I pressure washed everything and painted it out of a gun. I used a gallon of black paint called rust kill. It was only $25 for the whole gallon. Looks great.
Old Nov 2, 2009 | 04:58 PM
c.l.nye's Avatar
c.l.nye
If you want cheap,easy and fairly tough. I use rustolium black with enamel hardner from tractor supply and thin with recomended thinner and spray..
Old Nov 2, 2009 | 09:16 PM
1979F350/460's Avatar
1979F350/460
Thanks to all on all the different options. I'll let you know what I end up doing. Looks like the Rustoileum may do the trick.
Old Nov 4, 2009 | 06:55 AM
78ford351m's Avatar
78ford351m
Pics?
Old Nov 4, 2009 | 05:42 PM
hp246's Avatar
hp246
I've used Rustoleum, POR 15 and bed liner. Worst of the lot is Rustoleum. Lasted less than a summer. POR 15 has been either great or sucks. Very finicky material. Bed liner worked well. The key is the preparation for whatever you decide to use. sandblast first. Use one of the numerous formulas that lock in the rust. Then use your desired product.
Fastback460
27
Oct 12, 2014 12:03 PM
Effin-Yeti
Jun 24, 2014 10:25 PM
Machinegunmike
Aug 26, 2011 11:23 PM
54fever
Nov 21, 2006 11:05 AM
ethomps
Paint & Bodywork
Jun 5, 2004 10:26 AM
