2wd Front Leveling
Old Oct 30, 2009 | 08:08 AM
fifthwheel01's Avatar
fifthwheel01
2wd Front Leveling
I'm getting really itchy to level my truck( raise the front end). Thanks to F350-6 post on another threadhttps://www.ford-trucks.com/forums/a...1&d=1256858845
I can now see how everything goes together (simple spacers). My problem is I've never done anything heavier than replacing the pads .
Does any one have a set of instructions I can look at to see if its something I reallly want to tackle. Some of that looks like really heavy duty work and I may not have the appropriate tools, jacks, etc.
Old Oct 30, 2009 | 08:27 AM
mxracer3276's Avatar
mxracer3276
Here is a link to a set of instructions if this is the kit you are referring to. Hope this helps: http://www.daystarweb.com/attachment.../kf/p10508.pdf
Old Oct 30, 2009 | 08:41 AM
fifthwheel01
Hey THANKS Matt, that was fast and exactly what I needed. I've never done suspension before and didn't know if I had to mess with the big parts. Looks easy enough floor jack, jack stands, hand tools. And "spring compressor" is that something I should buy or "borrow" from parts store?
I dont have a kit yet so guess I'll do some shopping today.
Old Oct 30, 2009 | 08:44 AM
mxracer3276
Alright Johh no problem. It is really simple. I have never done anything with suspension before either and this was a breeze. I didnt use a spring compressor. I will PM you my phone number.
Old Oct 30, 2009 | 08:52 AM
mxracer3276
I PM'ed you my phone number. If you do end up getting this kit, give me a call if you have any questions. I have a few little tricks to installing this kit....
Old Oct 30, 2009 | 12:24 PM
fifthwheel01
Got your # on file, thanks. and i will call you when I get the set.
Did you have to change out your shocks? Do you have any before / after pics?
I pull a fifthwheel (who'd of guessed) and the back doesnt go down enough to keep my bed rails level with the 5er. Thinking this will really help AND look good too. Did you get a 2"or 2.5"?
Old Oct 30, 2009 | 01:27 PM
mxracer3276
I got the 2 inch system. No i did not have to replace my shocks either. Here is the link to my original thread. There you will find the before and after pics:
https://www.ford-trucks.com/forums/8...eling-kit.html
Old Oct 30, 2009 | 07:34 PM
F350-6's Avatar
F350-6
It's surprisingly simple to pull the spring. I did not use a spring compressor when I swapped my springs. If you've got a front sway bar, unbolt the U-shaped clamps on that. Then you just need a couple of jacks, a good extension to reach that lower nut, and you're in business.
tozir
2004 - 2008 F150
Jan 15, 2015 03:24 PM
hotrod351
16
Sep 12, 2014 10:59 AM
Partime
Oct 23, 2013 01:42 PM
stlrisk
Oct 27, 2009 02:59 PM
xxxcre10xxx
Jan 11, 2004 06:22 PM
