Chassis Exit Headers (460)
Old Oct 31, 2009 | 01:34 PM
kwemj 67's Avatar
kwemj 67
Smile
I have L&L headers on my 78, they are really well put together and no leaking problems because of the big thick flanges. My system is the same as " Blow'n 331" described his. I went with 3" straight back to a regular muffler on each side and dumped just infront of the rear spring hanger. Tucked it up along the frame rail and ran a cross-over by the transfer case. Nice and clean, not cooking your starter or notching frame rails.
Old Nov 2, 2009 | 08:40 AM
1979F350/460's Avatar
1979F350/460
Hey 75F350 What type of coating did you use on your frame? Sorry I know this is off the topic.
Old Nov 2, 2009 | 09:14 AM
75F350's Avatar
75F350
Jet Hot for the headers and Powder coated frame.
Old Nov 2, 2009 | 09:17 AM
1979F350/460
Thank you 75F350
Old Nov 2, 2009 | 02:59 PM
Broncoholic1's Avatar
Broncoholic1
That Jet Hot is nice I am lookin at a 460 now in the F350 since the 5.9 fell thru
I have a set of Hooker Super Comps for it. Might have to Jet Hot em.
Old Nov 2, 2009 | 07:10 PM
Bigbruce's Avatar
Bigbruce
Do you have any pictures of the cross over ? Did you make it like an H pipe ?
Old Nov 2, 2009 | 07:13 PM
Bigbruce's Avatar
Bigbruce
When you do the fender exits do you put the plastic fender well splash guards back in or do you have to leave them out ? What are the pros and cons of fender exit headers l V-S Chassis Exit headers ?
Old Nov 2, 2009 | 07:29 PM
kwemj 67's Avatar
kwemj 67
Smile
On the cross over, it is exactly the same as an H-pipe, just to equalize the pressure between both sides so when you are coasting down hill, etc., you will have less back popping. I just notched the metal inner aprons alittle for clearance and ran the plastic splash shields. Will try to post some pictures, but you could look at my album under my name. Take care. Kelley.
Old Nov 2, 2009 | 07:34 PM
Blown 331's Avatar
Blown 331
Plastic inner fenders stay in. I like the fenderwell exit because it keeps the area between the frame rails a little more open, its easier to get to the starter etc. Exhaust is super easy with fender well exits, nothing needs to be bent, you can just make it yourself plus its a lot easier to keep both sides of dual exhaust the same length. Exhaust heat is kept away from the transmission and transfer case. I don't see anything bad bout them, l love em!
william16339
Dec 22, 2016 04:55 AM
T_Cooksey88
May 20, 2016 10:05 AM
buckbr549
35
May 26, 2011 03:33 AM
Iversen-fords
26
Apr 10, 2011 10:20 PM
ERIC79XLT
1978 - 1996 Big Bronco
Jan 23, 2005 03:26 PM
