Starter grinding--going bad?
Old Oct 26, 2009 | 11:43 AM
msmith53's Avatar
msmith53
About every 8th or 10th time I start the truck, the starter will grind or whine for just a second or two, then grab hold again and start the truck with no problem. I figure the starter is going bad and needs to be replaced...or is something that can be fixed without replacing the whole starter? Checked all connections and they are good, clean and tight.
Old Oct 26, 2009 | 11:45 AM
61 uni's Avatar
61 uni
Check the mounting bolts. They are known to backout.
Old Oct 26, 2009 | 11:50 AM
riverrat41's Avatar
riverrat41
I agree^^.Mt top bolt needs to be fixed as well.It is about stripped.
PwerStroke99's Avatar
PwerStroke99
I AGREE with 61 uni, but also, your solenoid could e going bad and wont push the bendix out in certain spots. Also, u could have worn teeth on your flywheel.
Old Oct 26, 2009 | 12:34 PM
kirkharrod's Avatar
kirkharrod
Definitely could be worn teeth on the flywheel, but usually the grinding sound occurs less frequently than every 8-10 times. But it could certainly be the flywheel. I think someone told me you have to take the transmission out to replace the flywheel. Is that right? If so, definitely something to get done when I head down to BTS!
Old Oct 26, 2009 | 03:27 PM
flatbeder's Avatar
flatbeder
Do you have a auto or manual tranny? if you have a auto pull off the insp. plate and check the teeth on the flexplate/flywheel...it sounds to me like the bushings could be going out in the starter or the flexplate has been chipped or missing teeth...
Old Oct 26, 2009 | 03:35 PM
msmith53's Avatar
msmith53
Thanks for all the great help, guys! I have an auto. I'll check into all your suggestions, and when I know what's going on, I'll let you know. Again...thanks a bunch. Great info!
Old Oct 30, 2009 | 01:21 PM
msmith53's Avatar
msmith53
Update
Just thought I'd update you on the starter issue. Turns out it was the starter. Kevin and his crew at Black Magic Performance replaced it with a high performance starter that's about twice the size of the stock unit. Can't believe the difference! The new starter is about 20 times faster and just spins the engine...starts it in about 1 to 2 seconds, no grinding. Makes a world of difference heading into winter!! Thanks for all your help folks...I really appreciate your advice and input.
Old Oct 30, 2009 | 09:36 PM
flatbeder's Avatar
flatbeder
Glad to hear you got it fixed!
BFJARMAN
Modular V8 (4.6L, 5.4L)
Jul 14, 2021 10:08 AM
ConklinRacing08
May 5, 2020 01:53 PM
chiefsfootball
20
Dec 16, 2015 10:35 AM
birchwoodford
Mar 22, 2012 12:16 PM
400Nut
Mar 31, 2006 04:33 PM
