Sponsored by: Auxito
Torque converter drain plug?
Old Oct 24, 2009 | 03:05 PM
mjbll's Avatar
mjbll
I have a 02 screw with 5.4 engine.I am changing the trans fluid and am looking for the drain plug for the torque converter.I popped the rubber plug where you can see the teeth of the flywheel and spun engine around with screwdriver while looking for drain screw.Didnt see it,maybe I`m blind.Do I need to look somewhere else?I have the 4r70w trans I believe.
Old Oct 24, 2009 | 05:27 PM
projectSHO89's Avatar
projectSHO89
You don't have a TC drain plug....
Old Oct 24, 2009 | 07:19 PM
mjbll's Avatar
mjbll
Wow my 97 F150 and 98 Expy had same transmission and had drain plugs on converter.How do I get most of fluid out of transmission?The pan only has 4-5 qts.
Old Oct 24, 2009 | 07:45 PM
steve(ill)'s Avatar
steve(ill)
my 2001 has the plug. they stopped putting them in about 2002. If you want more out, you will have to take a line off from the trans to the radiator, and pump it out.
Old Oct 25, 2009 | 04:00 PM
green 1969 f100's Avatar
green 1969 f100
You are free to do as you wish however, I am convinced that the total flush is the way to go.
al0311
Aug 22, 2015 08:58 PM
05ExcursionLTD
Jun 19, 2009 07:15 AM
ispurlock2000
Aug 6, 2007 06:01 PM
omni
Jul 1, 2004 12:56 AM
jgates
May 22, 2002 09:33 AM
