What "coolant cocktail" is being used after installing the Dieselsite Filter? Everyone talks about how easy it is to install, but isn't the coolant used important too. Sorry if it sounds like the "EGR" valve between my ears is plugged. TIA.
Ford OEM?
Evans NPG+?
Other?
Never used it...I believe in not fixing what isn't broke...both Ford's and Valvoline's products meet the OEM spec for our cavitation sensitive engine. Its as simple as that...I beleive the Zerex G-05 is cheaper though.
