What Distributor Do I Have
Old Oct 20, 2009 | 06:47 PM
smkf100's Avatar
smkf100
I have a 66 F100 with a 352 in it. I bought a distributor cap and rotor and they would not work with the distributor. The distributor is not stock. I would like to buy a new distributor cap and rotor and not sure what to buy. Possbily some one can help me out with this issue. I have the numbers that are on the side of the distributor.
D5TE 12127 EA
5K8
Thanks
Old Oct 22, 2009 | 11:30 PM
customcab66's Avatar
customcab66
sounds like the right one not totaly sure but most of the ford caps and rotors will fit any of the older fords i know that the cap one my small block will fit the big block 390
Old Oct 22, 2009 | 11:41 PM
tbm3fan's Avatar
tbm3fan
Didn't the Duraspark begin to see use in Ford trucks around 1975-76 with the D5TE ID date and app...?
Old Oct 23, 2009 | 12:53 AM
daveengelson's Avatar
daveengelson
Came across link may find helpful: Check out ND's note #3
https://www.ford-trucks.com/forums/7...-72-fe390.html
Installed Duraspark ll in 65 from 76 donor. Make sure to confirm and cross reference P/N. Ended up using Napa Parts.
Electrontic Ign. Distributor: Napa P#: 48-2897
Rotor:FAI44
Duraspark II Module: Napa P#:TP40SB
Coil: Napa P#:IC21SB
Went with the large distributer cap with requires an adapter.
Old Oct 23, 2009 | 03:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TE 12127 EA // 5K8
D5TE-12127-EA = D5TZ12127E .. Distributor Assy (Motorcraft DA1428)
5K8 = Assembled October (K) 8, 1975 (5).
Original application: 1975/76 F100/350 360/390 with Breakerless (DuraSpark) ELECTRONIC Ignition.
1975/76 V8 dizzies do not use the base adapter. The adapter (D7VY12A217A) was first in 1977, when Ford changed the dizzy...again.
D5AZ12106A .. Distributor Cap (Motorcraft DH354).
D5AZ12200A .. Rotor (Motorcraft DR5A)
If you need a vacuum advance: D4OZ12370D (Motorcraft DD719)
Mitch:
ALL 1957/74 car/trucks (except Hipo's) used the same V8 dizzy cap (B7A12106A). This cap is BLACK.
1957/70 Hipo engines (289/302/312/390/406/427/428) used a different cap (B7AZ12106A). But...this cap, which is TAN, will also work on all other 1957/74 V8's.
Good luck finding a NOS original!
1975/76 V8's: D5AZ12106A. This cap is BLUE.
1977/79 V8's: D7AZ12106A. This cap is GREY...and, it looks totally different than previous dizzy caps. This cap uses the adapter.
Old Oct 23, 2009 | 07:00 AM
charliemccraney's Avatar
charliemccraney
ND,
Is the 75/76 cap completely different than the rest? I know the 77-79 cap, adapter, and rotor will fit on earlier distributors, such as my Y-block's distributor.
Old Oct 23, 2009 | 03:18 PM
NumberDummy
According to the car/truck parts catalogs, D5AZ12106A (1975/76) is different than 1957/74 (B7A12106A), 1977 and later (D7AZ12106A).
There is another V8 dizzy cap (FAB12106A), used on 1954/56 Y-blocks.
Chain autoparts store parts personnel are usually clueless, depend on what the 'puter sez. The 'puter may be correct, or...it may not be.
It wouldn't surprise me in the least...that the OP was sold an FAB12106A dizzy cap.
Old Oct 27, 2009 | 05:40 PM
smkf100's Avatar
smkf100
Thanks all for the great information. It is so nice to make a post and then all of this great information follows. I am going to stop by my favorite locally owned parts store tomorrow to get replacement parts.
Steve
52 USCG Panel
Mar 22, 2017 03:09 PM
jackietreehorn
19
Oct 16, 2016 06:01 PM
f-250.4x4.390
Oct 16, 2015 08:21 PM
KsCop
39
Dec 30, 2013 05:12 PM
FORDFAMILYOF3
Electrical Systems/Wiring
Jul 7, 2011 12:20 PM
