Climate control display gone
Old Oct 20, 2009 | 04:23 PM
JaySVX's Avatar
JaySVX
i looked for a fuse for it in the books, but didn't find one. Everything else works fine and as intended. I have no dispaly, nor do the buttons function, on my climate control. If anyone has any suggestions it would be greatly appreciated, being it's 35F out in the mornings these days...
Old Oct 20, 2009 | 05:19 PM
1's Avatar
The elctronic climate control seems to like to go out. There's been a few threads on this issue. Some have had luck with fuse issues, others needed a whole new unit. These are NOT cheap from ford $6-$800 if my memory is correct. I'd start hitting up junkyards if its not a fuse and you need a whole new unit.
Old Oct 20, 2009 | 05:26 PM
JaySVX's Avatar
JaySVX
Awesome. Just made my day. Should still be able to get heat through the overhead console right? Thanks for the info.
Old Oct 20, 2009 | 05:44 PM
JaySVX's Avatar
JaySVX
Sweet. found a screwing with the headlights option. lights on and off and on and off and bam, it was back. $800 be damned!
Old Oct 20, 2009 | 06:29 PM
jhooch's Avatar
jhooch
My '05 X did the same thing. It was an intermittent problem. Finally went for good. Luckily it was still under warranty as the whole unit had to be replaced.
Old Oct 20, 2009 | 07:22 PM
scottman70's Avatar
scottman70
Go out to your Ex, start the engine and then turn on your headlight manually and then turn them off and it should magically appear! Works for me the last 2 times that it happened to me. Why it fixes it who knows! Good luck I hope it works for you too!! Let me know!
Old Oct 20, 2009 | 07:46 PM
BigRy's Avatar
BigRy
Thats happened to me a few times also. I ended up turning the truck off and restarting it, and it would work, but i read someone posted here about the lheadlight switch, and I have done it a few times and it has worked. I think it has something do with the headlamps and a voltage spike with the AC or Heater being left on on startup. Probably a simple diode would fix it. But the turning on and off of the headlight switch is so much easier and quicker.
Old Oct 20, 2009 | 08:56 PM
JaySVX's Avatar
JaySVX
Yup, that's exactly what fixed my problem. I can't imagine the two systems even being connected. Maybe it's the dimmer function for the lights, but I would think that would be across the board, radio, instrument cluster, and all. Maybe it's the initiation power for the system that has to be reset, because it wasn't just hte display that was out, it wasn't functioning. No buttons responded, etc. Beh, it's done, I have heat on my 35F mornings.
Old Oct 20, 2009 | 08:58 PM
scottman70's Avatar
scottman70
Glad that worked for ya, it is crazy that it works?
alfie623
2009 - 2014 F150
Jan 1, 2013 08:49 PM
1997fordf350
Aug 9, 2012 05:23 PM
militarymonark
May 15, 2012 09:52 PM
lew52
2004 - 2008 F150
Mar 28, 2010 06:41 AM
