Climate control
Old Aug 9, 2012 | 11:55 AM
1997fordf350's Avatar
1997fordf350
Climate control
Hi when I put the climate control in the vent position it only comes out of the defrost vents and thats with any of them.
Old Aug 9, 2012 | 02:17 PM
Intimnasc's Avatar
Intimnasc
You probably have a vacuum leak somewhere. I would check all the vacuum lines associated with the AC controls.
Old Aug 9, 2012 | 02:41 PM
1997fordf350
Where is that located?
Old Aug 9, 2012 | 03:05 PM
rla2005's Avatar
rla2005
This one is the most common cause of HVAC issues like you describe:
courtesy of subford
Old Aug 9, 2012 | 03:12 PM
1997fordf350
Ok but mine has the 5 different lines coming in from the top and some of them are broke would that cause it?
Old Aug 9, 2012 | 03:35 PM
rla2005's Avatar
rla2005
5 different lines leading to the HVAC vacuum motor shown above? Never seen that in Ford truck of this vintage.
What causes broken vacuum lines? Age and heat. The plastic/vinyl vacuum lines Ford used were dirt cheap. Lucky any of them made it past the 10 year mark IMHO.
Old Aug 9, 2012 | 04:27 PM
1997fordf350
Ok how do I get new ones and I'll upload a picture
Old Aug 9, 2012 | 05:23 PM
rla2005's Avatar
rla2005
Replace them with rubber or silicone lines from a parts store.
AeroStarOwner
Aerostar
May 9, 2012 11:01 AM
pkwest
Sep 17, 2007 10:12 AM
jgc2521
Oct 25, 2004 05:26 AM
tombob
1978 - 1996 Big Bronco
Oct 11, 2004 01:13 PM
