Time for brakes
Old Oct 19, 2009 | 03:14 PM
natedog37's Avatar
natedog37
Time for brakes
I have a wonderful metal on metal sound coming from my rear brakes, so with 100k on the odo i thought it would be time for a complete brake job all the way around. I have to go up and down some pretty big hills every time I leave the house and my rotors get warped pretty fast, so I was thinking about going with some slotted and drilled rotors on the fronts at least. I'm sure somebody out there has run this set up, so I am wondering how you liked it?
Also what pads do you guys run, I see a lot of advertisements for the EBC Red, Yellow and Green stuff pads, what are your thoughts on these as well?
Thanks!
Old Oct 19, 2009 | 03:49 PM
rebelchevy02's Avatar
rebelchevy02
I have powerslots on all four corners of my truck. More important then the fact they are slotted, is the fact that they are cryogenically treated IMO. As far as pads go, Im 100% OEM. And you have to say OEM at the dealer or you will get the motorcraft aftermarket. They lasted over 100k on my truck and the rest of them at the shop. I had a set of carquest that I put on ONE time. Lasted 30k, and I chucked a pad, then ate up a caliper, and then lost the rotor aswell.. Never even heard the squeelers. Some will disagree with that, but thats been my past experiance. I love carquest brakes for "light duty" vehicles. Not for a diesel truck. The other pads I like are made by Hawk. People seem to like the pretty much.
Old Oct 19, 2009 | 05:15 PM
Izzy351's Avatar
Izzy351
I put cryo'ed PowerSlots up front with Hawk LTS pads. Still stock on the rear. Nice brakes, once they are broken in (VERY important).
Old Oct 19, 2009 | 05:19 PM
Mike Allen's Avatar
Mike Allen
I went with the ART setup on all fours, replaced the lines and fluid as well. Truck stops very well now.
ART setup is cryo'd as well.
Old Oct 19, 2009 | 05:29 PM
mechelement's Avatar
mechelement
NAPA Extreme Duty pads up front and the next step down in the rear. I have stock rotors all the way around without any vibes. I must say, the brakes on my wife's previous 2004 Cummins 3/4-ton were far superior to my current brakes. I really expected a lot more stopping power after the brake job on the PSD. Oh well.
Old Oct 19, 2009 | 06:42 PM
big poppa's Avatar
big poppa
I,m in need of some front brakes too, only got about 30,000 out of this last set, cheap set from Auto-Zone but my rotors I can get about another year out of my rotors so I'll throw another half decent set of brakes on it then next year do the powerslot and Hawk pads up-grade. Barry zx-250 mentioned to me about good deal on the Powerslot hawk pads he got a while back, maybe he'll chime in soon.
clintbonnie's Avatar
clintbonnie
Check out Power Stop for slotted rotors.. (drilled not really recommended from what I have read for our trucks) .. They are great rotors and run about $70 each including shipping.. I also used their ceramic pads..
Old Oct 19, 2009 | 07:09 PM
mechelement
Don't slotted rotors constantly cut off a little bit of brake pad each time you use the brakes? Do you guys just tear through pads with the quickness when running those rotors? How often are you replacing pads with those slotted rotors?
Old Oct 19, 2009 | 07:12 PM
rebelchevy02
When I destroyed the carquest pads, that was on stock rotors. With my powerslot cryo rotors, and OEM pads, I am around 50k at the moment. Probably do some maintenance this weekend, and I can give you the 32nds. Last I remember, they were in really good standings still.
Old Oct 19, 2009 | 08:42 PM
Izzy351's Avatar
Izzy351
I got mine from Barry's info -- they came from UltimateTruck.com
Old Oct 20, 2009 | 12:32 AM
natedog37's Avatar
natedog37
Thanks for all the good info, so sounds like the powerslots and oem pads should work good. What should I be looking to pay for em?
Izzy what was your "break in" time like?
Old Oct 20, 2009 | 12:44 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
You're not alone... was it passenger rear? My truck and my buddies truck (late 99) both spit out rear pass. side inner pad. Just seeing out of curiousity
Old Oct 20, 2009 | 08:35 AM
rebelchevy02
Drivers side rear for me.
Old Oct 20, 2009 | 02:32 PM
Mike Allen's Avatar
Mike Allen
I ran a set of ART slotted rotors for about 90K without issue. Pad still had plenty of life left.
the_auto_tech
Apr 27, 2014 10:39 AM
perryg114
Nov 9, 2010 06:40 PM
MadMedic20
Feb 18, 2009 09:30 PM
Ron Kelley
13
Oct 18, 2007 05:41 PM
mdpnh
Jul 13, 2005 12:06 PM
