My brake pedal was extremly hard to push , it was like the power brake was not working, this has happened twice know and I have been lucky ....
any ideas ???? Thanks Neil
It's more and likely your power steering pump is on it's way out... How is your steering.. ? Check the fluid level.. Pop.. According to his profile, he is driving a 2013 F250 with over 125K miles.. (I think he means a 2003)
And welcome to the forum !
Look in the power steering pump and make sure you have ATF in there instead of power steering fluid. The power steering pump also supplies boost to the brake system.
My brake pedal was extremly hard to push , it was like the power brake was not working, this has happened twice know and I have been lucky .... any ideas ???? Thanks Neil
Welcome to FTE. Flushing the ATF is much easier on a truck than a van, but it's still a good place to start. As mentioned, make sure to use ATF in the power steering system, not power steering fluid.
