maxi fuse #18
Old Oct 18, 2009 | 08:09 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
maxi fuse #18
what does the fuse #18 under the hood do i was checkin all my fuses under my hood and it was blown
Old Oct 18, 2009 | 08:30 PM
pjwoolw's Avatar
pjwoolw
Could be Trailer Battery Charge Relay. If I'm looking at the correct diagram.
Old Oct 18, 2009 | 08:35 PM
jimwilsonmasonry
whats a trailer charge battery relay do
Old Oct 18, 2009 | 10:08 PM
joe_13894's Avatar
joe_13894
Exactly what it says it does.
There is a relay in the small box next to the power distribution box. The coil of the relay is powered through fuse #5 (backup lamps) when the key is on.
Fuse #18 connects to the contacts on the trailer charge relay. When the key is on, 12V power is sent to the trailer connector to charge the battery in the trailer.
If you're not charging a trailer or camper battery, you don't care if fuse #18 is removed.
Old Oct 19, 2009 | 10:13 AM
jimwilsonmasonry
oh ok thanks guys
Old Oct 19, 2009 | 07:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
here is a pic of the relays and the power distribution box:
KefusJoe
Escape & Escape Hybrid
Mar 11, 2020 11:39 AM
delval
16
Aug 6, 2017 10:21 AM
andrewcollins2
15
Aug 28, 2016 08:21 PM
jsorrell84
Jan 15, 2013 05:52 AM
Leemakesmepee
Nov 24, 2012 04:44 PM
