maxi fuse #18
Old 10-18-2009, 08:09 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
jimwilsonmasonry is offline
maxi fuse #18
what does the fuse #18 under the hood do i was checkin all my fuses under my hood and it was blown
Old 10-18-2009, 08:30 PM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Could be Trailer Battery Charge Relay. If I'm looking at the correct diagram.
Old 10-18-2009, 08:35 PM
jimwilsonmasonry
whats a trailer charge battery relay do
Old 10-18-2009, 10:08 PM
joe_13894's Avatar
joe_13894
joe_13894 is offline
Exactly what it says it does.
There is a relay in the small box next to the power distribution box. The coil of the relay is powered through fuse #5 (backup lamps) when the key is on.
Fuse #18 connects to the contacts on the trailer charge relay. When the key is on, 12V power is sent to the trailer connector to charge the battery in the trailer.
If you're not charging a trailer or camper battery, you don't care if fuse #18 is removed.
Old 10-19-2009, 10:13 AM
jimwilsonmasonry
oh ok thanks guys
Old 10-19-2009, 07:59 PM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
here is a pic of the relays and the power distribution box:
KefusJoe
Escape & Escape Hybrid
03-11-2020 11:39 AM
delval
1997-2006 Expedition & Navigator
16
08-06-2017 10:21 AM
andrewcollins2
15
08-28-2016 08:21 PM
jsorrell84
01-15-2013 05:52 AM
Leemakesmepee
11-24-2012 04:44 PM
Quick Reply: maxi fuse #18
