No power on under dash fuse box
Old Oct 11, 2015 | 09:39 AM
delval's Avatar
delval
Question No power on under dash fuse box
No power on under dash fuse box but all power under hood fuse box
Old Oct 11, 2015 | 09:56 AM
alloro's Avatar
alloro
For what vehicle?
Old Oct 11, 2015 | 10:09 AM
delval's Avatar
delval
2000 Expy XLT 5.4 79,000 miles
Old Oct 11, 2015 | 11:05 AM
projectSHO89's Avatar
projectSHO89
Battery still there? Cables? Connected? Connectors or cables corroded? Fuse that feeds the interior fuse box okay?
Seriously, you need to provide relevant details and make (and report) observations, we're not psychic.
Old Oct 11, 2015 | 11:13 AM
delval's Avatar
delval
all cables are good, power is going to the under hood box. Didn't know there was a fuse under hood box to interior box. Thanks, I'll be checking that
Old Oct 11, 2015 | 11:49 AM
projectSHO89
Fuse F103, 50A (probably a maxifuse).
If the fuse is good but there's no power in the CJB (check fuse F1 for convenience), check the heavy tan/black wire that runs from the BJB to the CJB, specifically at the connectors at each fuse box looking for indications of burning or other signs of overheating.
Old Oct 11, 2015 | 11:52 AM
delval's Avatar
delval
Thanks for that info
Old Oct 11, 2015 | 02:46 PM
alloro's Avatar
alloro
Check fuses 103, 111, & 113 under the hood.
Old Oct 11, 2015 | 05:44 PM
delval's Avatar
delval
I'll check them as well, Thanks.....
I'll check them as well, thanks
Old Mar 20, 2017 | 03:01 PM
Bigcountry9168's Avatar
Bigcountry9168
No power
I got no power to the fuse box in the cab
But power to the panel under the hood
Old Mar 20, 2017 | 04:00 PM
projectSHO89
Are we supposed to just guess at what you're working on or what you've actually done?
This ain't twitter, there is no 140 character limit. Use your words and supply details.
Old Mar 20, 2017 | 06:44 PM
Bigcountry9168
Help
I need help I've got no power to the fuse panel under the dash. But I do have power to the one under the hood.
. I rebuilt the truck from the ground up
Old Mar 20, 2017 | 07:31 PM
Bigcountry9168
2001 f250 7.3
Old Mar 20, 2017 | 07:33 PM
Bigcountry9168
I got power to the three blocks that go into the cab
Old Mar 21, 2017 | 05:04 AM
projectSHO89
The you made an error in your wiring when it was put back together or something is still busted. Did you check the feed from fuse F22 in the BJB? That's the one that supplies ALWAYS HOT power to the CJB. BJB fuses F20 and F21 supply power to the ignition switch.
I have no idea what that means.
