Fuel filter location
Old Oct 17, 2009 | 04:28 PM
oldbob's Avatar
oldbob
is the fuel filter on the top and to the front of the 2002 7.3 power stroke
Old Oct 17, 2009 | 09:36 PM
Dave Sponaugle's Avatar
Dave Sponaugle
oldbob,
Welcome to FTE and the IDI diesel forum.
Wrong forum for that info, I will move this to the 1999 to 2003 7.3 Power Stroke forum though.
Old Oct 17, 2009 | 09:39 PM
jcrammell's Avatar
jcrammell
Yes it is. It is in a round container towards the front of the engine.
Old Oct 17, 2009 | 09:47 PM
jeffdoerr's Avatar
jeffdoerr
round container under the 7.3 logo plastic piece that sits on top of the motor.
Old Oct 17, 2009 | 10:06 PM
Izzy351's Avatar
Izzy351
When you change the filter, make sure the old O-ring comes off the center post. Open the drain. It drains out a tube by the front of the passenger side exh manifold -- a short piece of hose going to a catch can makes it much neater. Flush out the bottom of the fuel bowl being careful not to break the heating element down there. Close the drain, put in the new filter, and have someone turn the key to on & make sure the bowl starts to fill. Let if fill to nearly the top, then put the O-ring & lid on. Make sure you put the lid O-ring on in the right orientation (it's counter-intuitive IMHO), tighten it down, and turn the key on for about 20 seconds a couple times to get as much air out of the bowl as you can. Then crank it & enjoy...
Old Oct 17, 2009 | 10:18 PM
danskool's Avatar
danskool
Go Bills !
Bohen
6.7L Power Stroke Diesel
Feb 24, 2017 03:18 PM
big315
May 13, 2016 01:08 PM
Iaff113
Dec 12, 2014 08:37 PM
rockittsled
Feb 20, 2014 09:13 PM
AuRevoir
Dec 24, 2011 12:05 PM
