fuel pump w/ filter
Old Feb 19, 2014 | 11:47 PM
rockittsled's Avatar
rockittsled
fuel pump w/ filter
Does the fuel go from the line into the filter, sucked through the filter into the pump, and out into the line?
Old Feb 20, 2014 | 01:15 AM
rockittsled
NAPA AUTO PARTS
this is the pump I am asking about.
Old Feb 20, 2014 | 04:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by rockittsled
NAPA AUTO PARTS this is the pump I am asking about.
Factory installed: 1965/67 F100/350 352 & 1968/76 F100/350 360/390. This was the only fuel filter available for these trucks. There was also a 240/300 version.
Many people are unaware of the filter inside the pump, so they install an in-line filter. Meanwhile, the pump filter is getting more clogged up every day.
The canister (C3AZ-9355-A) and the corrugated paper cartridge filter (C4AZ-9365-B ~ Motorcraft FG-1A) available by themselves.
The canister is obsolete, 100's available NOS, Mac's Antique Auto Parts also has it. The filter is available from Ford/auto parts stores.
Old Feb 20, 2014 | 12:11 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I would say the pump would create suction thru the filter and to the line, and to the tank.
So....gas from tank, comes in line, thru filter, out the other fitting hole, up to carb....
I have made bad decisions before in my life, and this fuel routeing might be another one. lol
Look for an inlet and outlet marking?? I bet the line leads to outside of filter and the place for the fitting is fed from inside the filter or its the other way around?
You do need to know for sure what line goes where, before you kit the key.
Ok just off the phone with Chris at Napa...nice guy and explained alot. The silver inlet tube it sticking off the side of the filter and is for the 3/8 folt fuel line from the tank. You will need an 1/2 fitting to thread into the pump body (fitting is FN F-2B) it might be the same one on the end of the ridged line coming from the carb? That is the out let to the carb.
And yes fuel from tank, in line into outside of canister, then thru filter then sucked up and into the outlet to to carb.
Old Feb 20, 2014 | 12:29 PM
77&79F250's Avatar
77&79F250
Really....Fuel Pump Filter Canister | Dennis Carpenter Ford Restoration Parts
At least its available on line.... So this is considered NOS also, correct?
And maybe? http://www.cjponyparts.com/scott-dra...t-1965/p/FPB1/
http://www.aamshop.de/Fuel-Pump-Filt...er-FoMoCo-Logo
Line set up maybe here?
http://www.network54.com/Forum/74182...ter+cannister-
No, but here is an interesting statement about the filter.
"If you buy a used one you run the risk of getting the earlier inferior reproduction canister. They are still floating around out there and some sellers either don't know it or won't disclose it. They don't screw together properly and leak badly."
Old Feb 20, 2014 | 05:33 PM
NumberDummy
Carpenter made "a deal" with FoMoCo, can buy parts direct they are planning to obsolete.
So, this means that some of the parts DC is selling, are genuine Ford, not repro's.
Old Feb 20, 2014 | 09:00 PM
rockittsled
Good, I wanted to verify the filter cleaned the fuel before it hit the pump. I was aware of the repo canister and its' leaky rep from the 90's and will look to make sure I get the right one. Thanks for your help, I don't have one at hand to actually look at.
Old Feb 20, 2014 | 09:13 PM
NumberDummy
The canisters leaking is usually no fault of their own. People either reuse the original rubber gasket, a no no because it age cracks/shrinks.
Or they install a new gasket (comes with the filter)...without dabbing on a bit of grease.
Most people are unaware that cartridge fuel filters need a dab of grease on the mounting gasket, just like Spin-On oil filters do.
The other problem with the canisters: Many are stuck to the pump as they haven't been removed in a long time.
People place an adjustable oil filter wrench on them, then give a mighty tug. This action causes them to twist, then crack open.
MeanGreen72
21
Apr 27, 2026 06:25 AM
Biohazard74
Jan 31, 2019 11:07 PM
killerkjn
Nov 3, 2005 02:58 AM
Cdn Eh
Sep 15, 2003 06:19 PM
jgrasty7
Sep 18, 2002 09:00 PM
