Bronco II Ford Bronco II
do these things really flip?
Old Jan 19, 2011 | 03:29 AM
  #31
mdr617's Avatar
mdr617
yeah...i have had mine on two wheels a couple times, something else i have done that i thought looked really cool is when my brother was helping me film a little off-road video and the front end came off the ground about 1 foot while accelerating hard over a bump....didnt try too but it looked cool on film
Old Jan 21, 2011 | 09:39 PM
  #32
itsabowtime2's Avatar
itsabowtime2
My first nice newer truck was a BII. It was an 88 4x4. Bought it in '92. I had it for 5 years and never had an issue. And I know that I drove aggressively back then.
I believe the problem in part is people over compensate. They jerk the wheel one way then jerk it back and it is the second motion that causes you to loose control. You can roll anything.
Old Feb 16, 2011 | 01:50 PM
  #33
xbroncodos86x's Avatar
xbroncodos86x
Bronco II door striker
1986 bronco II so i was changing out the striker because i was tired of the door rattle and the clip inside door post that the striker bolts into fell into the car, am i screwed or what? cant drive a car where the door doesnt close, any ideas or help would be much appriciated
Old Feb 16, 2011 | 06:09 PM
  #34
fl1a's Avatar
fl1a
The plastic trim surrounding the rear of the door can be opened pretty easily. Look at the screw locations for the trim panel. Get yourself one of those flex handle long reach magnets. If i remember correctly you need to separate the panel from the rear of the door opening. It will allow some clearance for you to get a magnet between the panel and the metal. Remove all the screws from the plastic trim so it can move, or the screws will pull thru the trim. Get the magnet below the point it fell. It will have to go over the RABS module that is located behind where the nut fell. You should be able to get it, That is how I caught mine.
Old Jul 7, 2011 | 01:33 PM
  #35
BII Plow Truck's Avatar
BII Plow Truck
IMO the 'Twin-Traction Beam' is the issue.......the wheel tucks in like a Corvair.
Old Aug 30, 2011 | 08:40 PM
  #36
punkandpissed138's Avatar
punkandpissed138
the actual ratings for the B2s flipping are more 2wd than 4wd and its actually prettty scary how many do flip
Old Aug 31, 2011 | 05:36 AM
  #37
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Mine has been in my family since it was new 86.....once my mom sold it to me about 15 years ago.....the first thing I did was put a set of wheels on it that had a 3/4 of an inch more off set...made the width only 1.5 inches wider but drastically change the handling of it in a positive way...added stiff shocks on compression and soft up (larger tires not giant ones) ...it is wonderful ...the only thing IMO you need to worry is backing up on in incline...it will suck the front outside wheel under and can land on its side...again IMO
Old Oct 1, 2011 | 06:02 PM
  #38
fordtrucksj's Avatar
fordtrucksj
Any 4X4 can flip if you drive it like it's a sports car. Drive safe and use it for what it's meant for and you should be OK.
fordf11948
Apr 29, 2017 06:49 AM
lefty1953
Mar 17, 2017 09:06 AM
Chris Crews
Feb 12, 2017 11:54 AM
Restlesswildman
May 9, 2016 10:56 PM
kailor
Jan 16, 2007 06:20 AM
